Engine Misfire
  • Thread starter Thread starter ecosta
  • Start date Start date Feb 1, 2010
E
ecosta
  • Feb 1, 2010
Hey guys,
I'm having a problem with my motor misfiring. It started a few weeks ago that the engine was misfiring and then just stopped running. Figured out that the distributor was bad so I went to advance autoparts and got a rebuilt distributor for $65. The motor is running again but still misfires sometimes. When I start up the car in the morning, it runs great, no misfires. But then when I turn it on again like 1 hr later, the motor misfires. The only way it'll stop misfiring is if I let the car cool down completely. I already changed plugs and wires. Any idea what it could be? could it be that the distributor is just bad?
Thanx.
J
jka
5 Year Member
Jan 17, 2010
339
23
29
Feb 1, 2010
  • Feb 1, 2010
When you got that rebuilt distributor did it come with a new TFI module. If it did not that my be your problem also check your coil. You said it just misfires with it's hot and not when the car is cold or just started so that tell me the problem may be your coil or TFI module. So check those out good luck.
HISSIN50
34
129
Feb 2, 2010
  • Feb 2, 2010
Agreed with the above.
87WhiteStang1
182
  • Feb 3, 2010
sounds like TFI like metioned above. Another thought could be a vacuum leak because vacuum leaks can get worse when warmed up depending where its coming from. just a thought, also check timing. if its mostly stock, 12* would be a good starting point
M
Help! 2003 GT misfire when hot
  • Modular03
  • Feb 10, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Feb 13, 2026
Mustang5L5
M
2001 cobra ignition timing off
  • Mike3
  • Jul 13, 2026
  • SVT Tech Forum
SVT Tech Forum Aug 2, 2026
Mike3
M
Strange timing issue
  • 92 Bimini Blue
  • Sep 26, 2026
Fox 5.0 Mustang Tech Oct 20, 2026
rednotch
M
Misfire
  • Mike3
  • May 30, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 30, 2026
Mike3
M
A
Check Engine codes jumping around
  • azactor
  • Jan 9, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 24, 2026
DadLife0724
