I'm working on figuring out this stupid miss situation I'm having. Sometimes it will run fine, but there is an obvious miss in the passenger side head. It seems the passenger side is afterfiring into the exhaust making a loud pop sound. When I run the codes I get system lean, so it must be dumping more fuel in. I don't even know where to go on this. I thought maybe tps (new one), or idle set wrong, but nothing seems to help, so I was thinking maybe one of the injectors is going bad. Anyone got any ideas? Car has 130,000 and original injectors too.
Oh and when it bucks like it's missing its like it is when the gas tank is really low and the engine studders if you go around a corner too sharp.
Also it does this from start up too. I was thinking maybe I need a fpr to fix the problem with a little more tuning capacity.
