Engine mount plate?
  • Thread starter Thread starter 68coupe408
  • Start date Start date Nov 25, 2006
68coupe408
34
gville, nc
Nov 25, 2006
  • Nov 25, 2006
I did a search and did not see what I needed. I am looking to use a block plate instead of motor mounts. If anyone makes these plates, post up a link. The car vibrates too much with my current cam and this seems to be the best solution.
1320stang
4,329
23
89
Edmond, Oklahoma
Nov 25, 2006
  • Nov 25, 2006
Well, I'd suggest running solid motor mounts or at least an engine limiting device. Is it a drag only car? Are your motor mounts torn?
Campbell Enterprises sells front and mid plates for various brands and are among the cheapest I've seen. I've seen some guys eliminate the tranny mount when running motor plates, bad idea. You need a device to limit the front to rear deflection, I've gone up to such cars without a limiter and just shoved the front of the engine and watched it move front to rear. I also saw a kid without one hit the wall, caused his carb to go over half throttle 'cause the plates bent, scraped down the wall for an 1/8 mile before he hit the shutoff. Whole brand new '68 Camaro drag car ruined, only engine and tranny and roof still good. Even his fire suit was ruined.
68coupe408
34
gville, nc
Nov 25, 2006
  • Nov 25, 2006
Currently I have the stock rubber mounts that are worn. I was looking at a front plate setup because that would allow me to lower the engine slightly and stop the vibration. I am going to keep the transmission mounted as it is. Will the solid motor mounts stop the vibration? I thought they would only add to it.
I know of a drag car with a front plate and the car does not shake at all. My goal is to be able to adjust the carb while idling, instead of stabbing wildly at it.
65ShelbyClone
4,675
38
119
Antelope Valley, SoCal
Nov 25, 2006
  • Nov 25, 2006
Have you tried a torque strap of some sort on the driver's side of the engine? It sounds like the problem is the engine moving around in the bay rather than vibration in the car. Solid mounts would probably work also.
68coupe408
34
gville, nc
Nov 25, 2006
  • Nov 25, 2006
The engine is moving around causing what I call a vibration. The car will shake a coke bottle of the roof while idling. No strap on this engine currently. More or less a strap will help should a mount break again. Anyone running solid mounts with a healthy cam? I need something that will not rattle all the bolts loose.
washMO66
1,000
Washington, MO
Nov 25, 2006
  • Nov 25, 2006
I have TCP solid motor mounts with a fairly lopey cam and I do a nut and bolt on the car on a regular basis (just a safety thing for me). It doesn't rattle everything loose but I can't say everything is "always" tight.
They have worked great for me.
T
truck90278
382
Redondo Beach, CA
Nov 26, 2006
  • Nov 26, 2006
With the solid mounts, you may stop the movement of the engine in the chassis, but you will certainly still transmit ALL the lopeyness of the cam to the chassy. We are using the Ron Morris mounts which utilize a small urethane bushing with a cam that has some lope to it and we can feel the difference in the body (more engine vibration).
M
mustangguy289
42
  • Mar 1, 2007
Where can you find the TCP solid motor mounts. I am on there website and can not find them?
washMO66
1,000
Washington, MO
Mar 1, 2007
  • Mar 1, 2007
http://www.totalcontrolproducts.com/motormounts.html
M
mustangguy289
42
#10
  • Mar 1, 2007
  • #10
Oh ok i thought you meant solid as in having no bushing.
washMO66
1,000
Washington, MO
Mar 1, 2007
#11
  • Mar 1, 2007
  • #11
Sorry - Solid-er. There is not much give in them.
I would'nt go with a 100% solid mount, aside from going to a motor plate these should do anything you need them to do.
Or you can run a bolt through the factory mounts.
M
mustangguy289
42
#12
  • Mar 1, 2007
  • #12
I currently run a bolt through the ds mount and also have a chain rigged up to limit engine movement. What is your reasoning for not going 100%solid.
washMO66
1,000
Washington, MO
Mar 1, 2007
#13
  • Mar 1, 2007
  • #13
I would just think you would get more vibration through the car.... Just a preference thing for me since I drive my car to work a day or two a week during the summer. My new motor is going to be upwards of 750 or 800 HP and I still intend to use these same mounts.....
Like I said, a preference thing and your call.
TB
M
mustangdave
My rearend needs a stud and two nuts.
2,976
North Carolina
Mar 1, 2007
#14
  • Mar 1, 2007
  • #14
The engine won't shake as much but your car will shake worse. You won't be a ble to that coke bottle near it. Are u sure the engine is balanced properly?
69gmachine
576
Southern Maryland
Mar 1, 2007
#15
  • Mar 1, 2007
  • #15
Dynamics engineers used to have a saying: "vibration can neither be created nor destroyed, it can only be moved from one place to another". You need to fix the source of the vibration.
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
D
Question about EGR valve, replacement, and a part on the valve.
  • DPP
  • May 9, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech May 23, 2026
DPP
D
Car shakes when taking off help???
  • STANKYstangs
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 27, 2026
LILCBRA
Motor mounts question
  • djj62478
  • Mar 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 13, 2026
nickyb
