  • SN95 4.6L Mustang Tech
Engine Mounts = Shot
  • Thread starter Thread starter d98gt
  • Start date Start date Aug 12, 2006
1 of 2 Next Last
d98gt
4,505
59
204
SE Texas
Aug 12, 2006
  • Aug 12, 2006
Got the car on the rack today due to the vibration from a stop and found out that my engine mounts are toast. The engine is sitting lower on the passenger side which is throwing things off without a doubt.
Now I looked this up in the book while there and it's classified as a 2.7 hr job to swap them out so i'm going to call around tomorrow and see what some will charge to do this.
What engine mounts should I purchase? Any certain type? I'm going to also need to do my transmission mount, though that won't be a problem.
HoustonGT
Gilded Gelding
Apr 6, 2003
1,418
Houston
Aug 12, 2006
  • Aug 12, 2006
Hey, what symptoms were you experiencing with the shot motor mounts?
fastangboi
My first set of nuts vibrated themselves off.
Jul 26, 2006
274
Slowville
Aug 12, 2006
  • Aug 12, 2006
ive seen polyurithane ones advertised. im probably going to go with those when its time. right now my trans mount is done. so im replacing it with a poly.
blackink00
I missed a shift & stole Curt's money.
Mar 30, 2005
545
Tempe, AZ
Aug 12, 2006
  • Aug 12, 2006
i love my polys and there is no noticable vibration from them. not to bad to swap out took me about 3 hours on my back
d98gt
4,505
59
204
SE Texas
Aug 12, 2006
  • Aug 12, 2006
What brand do you suggest? I was thinking that I wouldn't have to spend the big bucks, but as long as I got poly that i'd be alright
As far as symptoms go.. Only from a stop while taking off slow or regularly I get a vibration which isn't really rough, though it's definitly there. It only happens from a dead stop and when taking off slow. I made a post about it when it first started to get worse http://forums.stangnet.com/showthread.php?t=647787 as I figured it was the universal joints.
I know it might sound odd for me to have thought that, though since the engine is "bouncing" when slowly taking off it's throwing everything else off.
DTNODYA
831
  • Aug 12, 2006
Interesting indeed ... my car is 'vibrating' also from a dead stop. It isn't terrible or anything but I thought my clutch was going bad or somethin'.
Probably a stupid question: How do you check your motor mounts?
blackink00
Mar 30, 2005
545
Tempe, AZ
Aug 12, 2006
  • Aug 12, 2006
i think i got energy suspension ones but i think they would all be the same.
d98gt
4,505
59
204
SE Texas
Aug 12, 2006
  • Aug 12, 2006
I could tell by just looking at mine that they were totally gone. The passenger side one had a little bit of oil on it and I guess thats what made it give way.
As for looking at them.. I guess you could view them from going up on ramps or anything such as that, though I have a family member that works at a local Dodge dealership and brought it to him and we put it on the lift so we could walk all under the car to see what was going on. While there, I talked to their gear tech and he told me he'd install gears for $75-$100 for me.
d98gt
4,505
59
204
SE Texas
Aug 13, 2006
  • Aug 13, 2006
What should I expect to pay for some new motor mounts? The cheaper the better of course
Links would be great
COramprat
...I can take it. I think.
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
Aug 13, 2006
#10
  • Aug 13, 2006
  • #10
I think the guy who did my mounts charged about 400. I'm not sure though because it was an insurance claim after I was rear ended. He did say it was a pain to do.
The symptoms of my bad mounts was a vibration once the car was started. It stayed steady until you got up to about 30mph then went away.
blackink00
Mar 30, 2005
545
Tempe, AZ
Aug 13, 2006
#11
  • Aug 13, 2006
  • #11
i think there around $120. there not really a pain just have to undo the starter on the passenger side
jasonh_86
I
May 20, 2005
1,156
Arkansas
Aug 13, 2006
#12
  • Aug 13, 2006
  • #12
My car shakes when i'm at a stop too.... but then again I do have VT Stage 2's ... I will probably need motor mounts soon tho
d98gt
4,505
59
204
SE Texas
Aug 13, 2006
#13
  • Aug 13, 2006
  • #13
I'm hoping for it to be cheaper than the $120, I guess I need to look around and see what I can find. Anything is better than factory broken ones
I forgot to mention what happens when the car cranks. It cranks up pretty rough due to the passenger mount being toast.
jasonh_86
I
May 20, 2005
1,156
Arkansas
Aug 13, 2006
#14
  • Aug 13, 2006
  • #14
.. I wonder if one or both of mine are shot..
d98gt
4,505
59
204
SE Texas
Aug 13, 2006
#15
  • Aug 13, 2006
  • #15
Well I'm pushing 140K miles so it's expected for this to be the case for me. Parts like this are going to wear down eventually and I guess I should have thought about this problem sooner
COramprat
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
Aug 13, 2006
#16
  • Aug 13, 2006
  • #16
Just brake check the next tailgaiter you come across. Might ding up you bumper but you can claim it broke the engine mounts.
d98gt
4,505
59
204
SE Texas
Aug 13, 2006
#17
  • Aug 13, 2006
  • #17
They'd total my POS
After looking at prices of some of these kits, I'm leaning towards the maximum motorsport solid motor mounts. $70 for them and MM has great quality products and not many will argue with that statement.
http://www.stangsuspension.com/store/comersus_viewitem.asp?idproduct=1120
Anyone see a problem with that?
blackink00
Mar 30, 2005
545
Tempe, AZ
Aug 14, 2006
#18
  • Aug 14, 2006
  • #18
i wouldnt go solid at all unless its a straight drag car. it would vibrate the car like crazy and probably start to twist your chassis. stay away from solids.
d98gt
4,505
59
204
SE Texas
Aug 14, 2006
#19
  • Aug 14, 2006
  • #19
Well thats good info then
I'm looking to get the parts as cheap as possible. Just need to fix this asap before it leads to more problems. I'll even go with a factory mount if needed.
Any clue where to look for CHEAP mounts? I don't want to pay $119+ for a pair
blackink00
Mar 30, 2005
545
Tempe, AZ
Aug 14, 2006
#20
  • Aug 14, 2006
  • #20
i couldnt find any urathanes for cheaper then that. the stockers aint that bad and there really cheap. theyll just wear out faster though.
1 of 2 Next Last
J
Bad Vibration
  • jefffletch47
  • Feb 12, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 2, 2026
dgrinnan
D
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
O
Sooty/Oily Front Engine & Pulleys
  • ozenator
  • Jun 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 22, 2026
Blackhawkxx
D
Brake & Suspension Rebuild
  • DuluthFoxbody
  • Monday at 4:00 PM
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Today at 9:10 AM
DuluthFoxbody
D
