Engine Pull Out
MikeKnopfler
South Carolina
In the spring time I purchased a 91 LX 5.0 that had been sitting for a while but does run and drive. We plan to pull the engine to repair the leaking oil pan gasket in the coming months but I am thinking that while the engine is out this is a great time to make any repair or modifications to the engine. Below is a current list of what the engine has when I bought it.
Stock heads - from what I can tell
Ford Racing B303 cam
Edlebrock Performer 5.0 RPM II intake manifold
BBK 65mm throttle body and spacer
MAC shorty headers
stock injectors (I believe as beige in color)
Under drive pulley
So my question is, what is the best way to tell if I need to tear the whole motor apart or not? It leaks oil but does not seem to burn oil as we have not needed to add oil since last oil change a few months back and we don't have any oil residue at the exhaust. It does have a high end (4k rpm) miss/sputter which leads me to believe I need new injectors. Once I have the oil pan off I can get a visual of the crank and such but obviously would need to take a part the upper half to get to heads and pistons. Would like to get the horsepower up and with the cam/intake it may be possible. Probably need new heads to hit over 300+ horsepower at the wheels. Would like to hear thoughts / opinions / experience on the subject.
  • Sponsors(?)
General karthief
Mod Dude
Aug 25, 2016
19,258
6,397
193
polk county florida
Get it running right before you pull the engine. A sputter or miss at 4k rpms likely is not the injectors.
Go to the 5.0 tech forum and hit the technical/how to threads for diagnostic/trouble shooting and tips on getting to the hp you seek.
Make a plan before you yank out that engine. Having what you need on hand makes things go much smoother.
