There are two different syles of rod bearings... ones that that are designed for a chamfered crank journal and ones for non chamfered crank journals. If you have a stock crank, you need the chamfered ones. If you look at the crank journal, the area where the shiny finished round journal meets the unfinished vertical part of the crank, it's not a sharp inside corner... it is rounded off. ( see pic below/red arrow)This mandates use of bearings that have a bevel on one side of the bearing... this side must face the rounded inside corner... so when both rod bearings are installed, the bevels on each must face away from each other. You may just have the wrong bearings or you have the right ones and they aren't oriented correctly. Many a new engine builder has not taken this into account and suffers the consequences... don't be that guy.
