  • SN95 4.6L Mustang Tech
Engine rebuild - upgrade??
  • Thread starter Thread starter 53BigDog
  • Start date Start date Dec 29, 2005
53BigDog
2,331
Palm Harbor, FL
Dec 29, 2005
  • Dec 29, 2005
Need some advice....
Ok long story short.....
Had knocking sound in 97 4.6L SOHC
Thought it was valves, rocker arms, cams, etc (something top end)
Performed a PI head swap for ****nit and giggles
Didn't fix knocking sound
Now have entire motor pulled out of car looking at possible bad crank bearing
Long term plans were to yank old motor and drop 03 cobra ford racing motor
Since motor is out - Figured I would rebuilt 9 year old, 150K motor
Money already spent on PI heads, more money spent on rebuild = no 03 cobra motor in near future.
Wanna rebuild strong engine with many options.....need those options
Car is daily driver with weekend warrior racing.
Looking for fun solid car.
Driver is very mechanically inclined but not to educated on major power adders
Ideas/Options: Stroker Kit, Bore (no idea but read about in other posts), future supercharger, rebuild stock, ??????
Suggest away, spend my money!
billfisher
1,296
huntsville, AL
Dec 29, 2005
  • Dec 29, 2005
i pi'd mine then pulled it out. get 5.4 3v. expensive but worth it.
Rick 91GT
Mustang Master
95
99
PA
Dec 29, 2005
  • Dec 29, 2005
Well be prepared everthing for it is expensive..lol
Don't need to stroke to make good power with a blower or turbo. Use a good forged crank, 4340 H-beam rod, good pistons, rings and bearings, ARP studs both main and head and you should have a bullet proof bottom end.
I'm working on a customer 96 32v Cobra motor currently, custom billet cam, lots of head work and valvetrain, ARP studs, forged bottom end, D1SC with all the goodies....not cheap but it will hold a lot of power and should put down numbers in the high 500hp with ease....
DBMSTNG
I fantasize about it being BIG!
2,120
not quite here
Dec 29, 2005
  • Dec 29, 2005
forged internals with 19cc dished pistons and MPH stage 2.5 heads with "Chad's cams". then supercharge it later on down the road.
5.0's 4 ever
The #1 Stunna
5,794
Orlando, FL
Dec 29, 2005
  • Dec 29, 2005
Pretty much it depends on if you are going n/a or power adder. N/A I would suggest a stroker kit, new cams, the necessary valvetrain upgrade, high compression, and some work on the heads. If going forced induction go with forged internals with low compression and let the blower or turbo make the power for you. I have a complete 99 cobra engine with teksid block that needs a rebuild if you are interested instead of building up your 2v. Al Papitto of Boss 330 Racing builds great modular motors in vero beach, he built the shortblock I run in my 96.
T
TGJ
1,049
  • Dec 30, 2005
If you are looking to stay N/A, I would suggest either the Big-Bore or a built stock displaced motor, ported heads, compression ratio should be10.5:1 - 11:1 for pump fuel, Comp 270AH or Crower Stg II PI cams, and a good exhaust system.
If you want a Power Adder, depending what you are wanting, either the KB 2.2 unit or a good Centrifugal SC, I would probably use a built stock displaced motor or a Big-Bore here as well. I would do the above again, but aim for an 8.5:1 - 9:1 Compression ratio with the power adder.
You will need an aluminum block for a Big-Bore. I would suggest an aluminum block for what ever you plan to do. They are lighter and can handle big power.
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
Engine Motor swap from a 2003 Explorer
  • 1996mustang new
  • Oct 9, 2025
SN95 4.6L Mustang Tech Oct 16, 2025
squeak93
J
'04 3.8L V6 mineral deposits and oil on #3 cylinder. Does it need a rebuild or something simpler?
  • joeybuddy96
  • Mar 18, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 29, 2026
gkomo
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
What's it Worth? 2000 GT
  • Mustang5L5
  • May 8, 2026
  • What is it Worth?!?!?
What is it Worth?!?!? Jun 13, 2026
KRUISR
