well i was lookin on summit at rotating assemblies to rebuild my engine next year. what is the rod length for a stock 88 gt?? whats the Actual Engine CID (des)?? i was thinkin thi would be a decsent kit $879.95
Actual Engine CID (des): 306
Pistons Included: Yes
Piston Material: Hypereutectic aluminum
Piston Style: Flat
Dish Volume (cc): 6.5
Valve Reliefs: Two
Wrist Pin Style: Floating
Piston Rings Included: Yes
Piston Ring Facing Material: Moly
Piston and Ring Oversize (in): 0.030 in.
Crankshaft Included: Yes
Crankshaft Material: Cast iron
Rear Main Seal Style: 1-piece
Balanced: No
Engine Balance: External
Balance Style: 50 oz. imbalance
Connecting Rods Included: Yes
Connecting Rod Material: Cast iron
Connecting Rod Beam Style: I-beam
Rod Bearings Included: Yes
Main Bearings Included: Yes
Gaskets Included: Yes
Oil Pump Included: Yes
Oil Pump Style: Wet sump
Camshaft Included: No
Lifters Included: No
Timing Chain and Gears Included: No
Quantity: Sold as a kit.
Build your engine the right way.
Rotating Assembly, Ford, 302, Kit
These Summit engine rotating kits are designed to help you get started on your engine the right way. The kits are configured to give you quality parts at a great price. They include a crankshaft, connecting rods, pistons, piston rings, rod and main bearings, gaskets, and Various oil pump configurations are available depending on applications.
what ya guys think?? then i was gonna buy a cam and lifetr then a throttle body.
Piston Style: Flat
Valve Reliefs: Two
Balanced: No
