  • 1994 - 1995 Specific Tech
engine running rough
  • Thread starter Thread starter hookups333
  • Start date Start date Dec 8, 2008
H
hookups333
154
Jax Florida
Dec 8, 2008
  • Dec 8, 2008
well it started the other day when sitting in traffic and i noticed steam from under my hood. Well my guage didnt say that it was overheating but stock guages prolly arent the best. Well it was leaking out of one the coolant hoses going to the oil filter adapter. Welll now that i get it home it runs really rough and when i filled the radiator the water was really bubbly like soap. There is no water in the oil and when the car is running it the water bubbles out. I have taken out all of the plugs but i dont remember the plug symptoms of blown headgasket, but there is no gunk on the plugs or anything. I believe it could be a lower intake gasket into the cylinder or a blown head gasket into the cylinder. What do yall think? Oh I dont have a pressure tester so i couldnt do that.
Yellow302
789
NJ
Dec 9, 2008
  • Dec 9, 2008
Oil filler adapter? your talking about the tube going from the fill neck to the intake tube?
worst case... If so that's not coolant should be oil vapor. If you have steam, i had alot of steam when i blew my head gaskets. It could also be a lower intake gasket.
best case you have a leak from the pipe that goes to your heater core. I had to make my own rubber tubing for that pipe because its discontinued from ford. junkyard special only.
Yellow302
789
NJ
Dec 9, 2008
  • Dec 9, 2008
if it turns a white bubbly foam, tan or brown you blew a gasket somewhere
Chythar
Recently finished repairing my rear
20+ Year Stangneter
Aug 26, 2004
2,373
140
113
Foothill Ranch, CA
Dec 9, 2008
  • Dec 9, 2008
My old 94 V6 engine blew the head gasket twice, it was pushing exhaust into the coolant. This sounds like what you have going on. When the engine cools down, pop the radiator cap and immediately sniff around the water neck. If you smell exhaust, you've got a blown head gasket.
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Aug 4, 2026
jake411
J
96 GT 4.6 w/ dirty spark plug well
  • Mustang Momma
  • Apr 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 9, 2026
LILCBRA
Engine Another no start after washing engine bay
  • bruno
  • Apr 26, 2026
Fox 5.0 Mustang Tech May 7, 2026
AeroCoupe
Engine 1994 5.0 refuses to idle
  • FordFanatic1894
  • Jul 20, 2025
1994 - 1995 Specific Tech Jul 22, 2025
General karthief
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
MadSquirrelTech
