engine shakes
  • Thread starter Thread starter wruddy
  • Start date Start date Apr 17, 2005
W
wruddy
71
Oxford, PA
Apr 17, 2005
  • Apr 17, 2005
long story - short - 94 gt stock
Engine shake came on quick.
Done so far....
*Changed fuel filter, plugs, wires, cap, rotor, pvc valve
*clean MAF
*clean K&N air filter
*looked and did not find any vacumn line leaks
*Hook up two cans injector cleaner to fuel rails and ran it thru - improved 80%
*ran two cans injector thru two tanks of gas - no improvement.
*pulled injectors, soaked them in cleaner, replaced one that was not allowing fuel through. Car ran the best it has ever run with no engine shake and lots of new found pickup for 30 miles. then shake came back slowly until it is now shaking so bad I am afraid to drive it.
what next - clean fuel tank, blow out fuel lines, reclean injectors?
Any ideas or suggestions welcome.
green
291
  • Apr 17, 2005
if its shakeing that bad i would take off the serpentine belt and check out the harmonic balancer.
Mustang5L5
Mod Dude
Feb 18, 2001
43,366
18,112
224
Massachusetts
Apr 17, 2005
  • Apr 17, 2005
How are the motor mounts???
I
Idwitheld-1`
335
Portland Oregon
Apr 17, 2005
  • Apr 17, 2005
what is the fuel pressure at?
vristang
4,933
101
124
Seattle
Apr 17, 2005
  • Apr 17, 2005
Is there a loss of power? Does the shake vary with engine speed or load? Are there any unusual sounds coming from the motor/trans? Does the motor shake when you take it out of gear? Is there a difference between when you are driving and sitting at a stop?
SMOKEDYA
20+ Year Stangneter
Jul 13, 2003
3,637
Tucson AZ
Apr 17, 2005
  • Apr 17, 2005
i would say harmonic balencer as well! peace
john
Y
yogi_stvl
53
Sacramento
Apr 17, 2005
  • Apr 17, 2005
my vote is for motor mounts... engine movement would be very evident if the mounts suck
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
Electrical 88 EEC Injectors batch firing ?
  • Dustin 86GT
  • Dec 8, 2025
Fox 5.0 Mustang Tech Jan 8, 2026
gkomo
9
Forced Induction Prepping for supercharger on non-stock build
  • 91fox427
  • Nov 25, 2025
Fox 5.0 Mustang Tech Jan 5, 2026
Qtrhrse23
G
Sputtering/misfiring below 2500rpm
  • Godless
  • Sep 14, 2025
2005 - 2014 S-197 Mustang -General/Talk- Sep 14, 2025
gkomo
  • dan50
  • Jul 18, 2026
dan50
