  • SN95 4.6L Mustang Tech
engine "sputtering" problem
  • Thread starter Thread starter 98stangv8
  • Start date Start date Feb 21, 2004
98stangv8
1,036
fayetteville, nc
Feb 21, 2004
  • Feb 21, 2004
ok...I have a 98gt...just replaced the fuel rail with one from a 97 (so I could change the regulator...can't do it on a 98)...I also added a c & l plenum...now it seems that my engine is sputtering...not all the time...just when I hammer it or sometimes at about 3/4 throttle...it FEELS like when a spark plug isn't working...or something along that line...like a cylinder isn't firing the correct way...
any thoughts?
thank you!
Spreadman
two wheels
Houston, TX
Feb 22, 2004
  • Feb 22, 2004
Could have a bad injector, or water in your gas. My car does the same thing when I get a bad tank of gas. I say run through that tank and then fill up at a reputable station and see what happens.
98stangv8
1,036
fayetteville, nc
Feb 22, 2004
  • Feb 22, 2004
hmmm..maybe bad injector...I actually just refilled last night, hoping that was the problem...I checked all the connections for the spark plug wires...all tight...may be a bad plug...thanks for the help..
Spreadman
two wheels
Houston, TX
Feb 22, 2004
  • Feb 22, 2004
Also, throw some STP Injector Cleaner in your tank before you fill up. I did that when I got some really bad gas and it seemed to help. I almost had to syphon it all out it was running so bad.
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
K
Electrical 2000 GT Intermittent Engine Shutdown In Motion - DTC U1262
  • kenster1092
  • Apr 13, 2026
SN95 4.6L Mustang Tech Apr 24, 2026
squeak93
I
Engine Insane fuel trims +25% LTFT Bank 1, -16% LTFT Bank 2
  • imw_stl
  • Aug 31, 2025
SN95 4.6L Mustang Tech Sep 19, 2025
Mustang5L5
I
98 Mustang GT dying
  • ItsMason
  • May 14, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 25, 2026
lenzgt
L
  • Gulftown980x
  • Jul 29, 2026
squeak93
