Engine stall help
UNVMATT
294
COLUMBUS
Hey people.
I have a 2000 GT..Its got about 100K miles now..
I had a problem before with the engine not wanting to idle so I changed the IAC..that fixed that problem..
However for the past few months another problem has developed. Whenever Im cruising then push the clutch in to coast to slow down or whatever the engine starts to drop to idle then fluctuates around 500rpm then completely dies (which makes it hard to steer and stop).. Also whenever Im sitting at a redlight it wants to idle around 500rpm and then it will fluctuate between 500-1000rpm or die altogether.
Any idea on what I can do to fix the problem? Ive thought about getting another IAC but Im not sure that will fix the problem.
Thanks
