  • 1994 - 1995 Specific Tech
Engine Stalls
  • Thread starter Thread starter blurry
  • Start date Start date Oct 10, 2006
blurry
31
Maryland
Oct 10, 2006
  • Oct 10, 2006
Whenever I start the car on a cold morning or its been sitting for hours, it will rev up to like 1500rpms then drop to 1000rpms, then drop and drop until the car stalls out. After starting it back up, I give it some gas to keep it around 1000rpms.
Also when I'm driving has done it twice. After either being at a high rpm like 4000rpm then quickly put it in neutral and hit the brake to stop, the car sometimes will drop so low it stalls out again.
What could be the problem?
F
fordtech28
312
Riverside Cali.
Oct 11, 2006
  • Oct 11, 2006
When was the last time you clean your maf sensor the idle control sensor and adjusted your Throttle position sensor?These three sensors play a big role in idleling the car and the performance of the car especially the idle control sensor start with that one clean it out and see if that helps.
J
Engine Stalling
  • josh40tay
  • Oct 20, 2026
JD1964
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
M
3.8 start problems. New edge 2003
  • Mayk.i.
  • Oct 2, 2025
1996 - 2004 SN95 Mustang -General/Talk- Oct 3, 2025
manicmechanic007
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
