Engine Stand question...
  • Thread starter Thread starter Killer50stang
  • Start date Start date Oct 29, 2005
Killer50stang
632
  • Oct 29, 2005
Okay, on my engine stand and I'm sure on most I have 4 arms that connect to the back of my motor. I guess I'm supposed to use the bolts I had from the tranny so mount to the engine? If so, the bolts only go part way through the arms and there's no way it will hold the motor. I know this is a stupid question but I would like to get this puppy mounted to the stand. I guess the clutch should probably come off too. It's still on the cherry picker, any tips of getting it on the stand?
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Oct 29, 2005
  • Oct 29, 2005
I had to run to the hardware store for some grade 8 bolts to hold my engine. I wish I could give you a size, but it only took me a second to grab a quick measurement of the length needed. Other than that, there's really not much to getting it on the stand. Just be careful if you turn the engine upside down, forgetting that it had coolant left in the block
superhuaman
907
Harrisburg, PA
Oct 29, 2005
  • Oct 29, 2005
If it is a 302, the bolts are 7/16", just like the head bolts. (hint, hint) They might be too long, in which case you'd need to washers unde the bolt heads.
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Oct 29, 2005
  • Oct 29, 2005
If you want to leave the clutch on, you'll need longer grade 8 bolts -- hardware store as instructed above.
Putting it on the stand isn't rocket science --- lower the motor on the picker until it lines up with the stand; put the 4 bolts through and tighten 'em down; gently lower the picker til the stand picks up the weight and the chain/cable goes slack; unhook it.
Be certain you get Grade 8 bolts -- broken bolts and dropping one off the stand can do all kinds of damage to body parts, engine parts and even the concrete.
BlownFiveLiter
18
108
Chicagoland
Oct 29, 2005
  • Oct 29, 2005
I couldn't agree more. If you enjoy having your feet and toes attached, absolutely use grade 8 bolts. It may seem to be holding well without them, but when you start torquing down cylinder heads or something, and start putting more stress on the bolts, you might be able to get out of the way in time, but I wouldn't chance it.
04sleeper
2,674
14
89
Dallas, TX
Oct 30, 2005
  • Oct 30, 2005
I have used this before. Worked fine.
Grn92LX
Fidanza Man!
6,819
64
129
New York
Oct 30, 2005
  • Oct 30, 2005
Yep, I use old arp head bolts to hold mine on the stand. The bolts are a bit long so you'll need a bunch of washers to space the bolts out.
Killer50stang
632
  • Oct 30, 2005
Yeah, this sucks to do. I'll just leave it on the picker until I get the correct bolts. 4 bolts to hold a motor on seems like not much...
Mustang5L5
Mod Dude
Feb 18, 2001
43,371
18,119
224
Massachusetts
Oct 30, 2005
  • Oct 30, 2005
If you use grade 8, they will be plenty strong.
4 is overkill, you could hold it with 2 if you wanted.
Grn92LX
Fidanza Man!
6,819
64
129
New York
Oct 30, 2005
#10
  • Oct 30, 2005
  • #10
I picked up some grade 8 bolts for my water pump
Mustang5L5
Mod Dude
Feb 18, 2001
43,371
18,119
224
Massachusetts
Oct 30, 2005
#11
  • Oct 30, 2005
  • #11
Also, there are SAE Grade 8.2 bolts...but good luck finding those they are kinda rare.
Cap bolts are slightly stronger than Grade 8 as well.
superhuaman
907
Harrisburg, PA
Oct 30, 2005
#12
  • Oct 30, 2005
  • #12
Nice ride/avatar 89sleeper!! Hopefully mine will look like that good when I'm done. But in red, of course.
ram360
2,162
Pennsylvania
Oct 30, 2005
#13
  • Oct 30, 2005
  • #13
don't over tighten the block to the stand.
04sleeper
2,674
14
89
Dallas, TX
Oct 30, 2005
#14
  • Oct 30, 2005
  • #14
Thanks.
Click on my page if you want to see more pictures of it.
K
Engine Gt40p vs 180 procomp
  • Kleinjj27
  • Oct 27, 2026
Fox 5.0 Mustang Tech Nov 3, 2026
Kleinjj27
K
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
Electrical/engine bay harness questions
  • djj62478
  • May 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 6, 2026
djj62478
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
