engine starting to smoke
Black GT
148
9
28
Jacksonville, Florida
I am starting to notice that while sitting in slow lines like a drive thru blue smoke coming from my tailpipes. The only times it is present is after idling a couple minutes when I give it gas to let the clutch out in 1st gear. Is there anything other than worn rings that could be causing this? Is a complete engine rebuild in the near future? It does not smoke while driving only when I accelerate after idling for 3-5 minutes.
First, I’d check the PCV to see it is closing like it should or instead passing oil. You didn't mention year or mileage, but if not PCV, I'd suspect valve seals.
Diagnose the problem first. Do a compression check and most importantly, do a cylinder leak down test. Those two, especially the second one, will tell you the condition of the engine. Blowing blue (oil) smoke at a low idle or off idle only is a good sign of valve stem seals leaking. There's so much vacuum at that time the engine can "suck" it in the cylinders then blow it out on acceleration. If you had a lot of smoke at high speed or cruising, that points to rings. If in case it is valve stem seals, that can be done in the car without pulling heads. Also, I've never heard of a head gasket causing an oil burn problem.
Thanks, I take that as good news. I had a friend follow me and there is no smoke at all while driving at speed. I am going to try and do a leak down test tomorrow. I need to get the tool with the gauges for the test. I watched several video's on the leak down test and replacing the valve stem seals. I ordered a valve spring compressor tool from ebay a few minutes ago. Looks like something I can do myself. I do have a couple of questions though. My main concern especially replacing the seals is can you put to much air pressure in the cylinder to hold the valve up when replacing the seals? I have a 60 gallon 8HP compressor I use to paint cars with. Compressor shuts off @ 130 psi and comes on @ 90 psi. Just want to be sure I will be ok with those pressures or if need be I can regulate it down some.. I would like to replace the valve springs at the same time I do the seals. I am a believer in using motorcraft parts unless there is another brand just as good or better. Also a little concerned about removing and installing the camshafts and getting them back in the same spots (timing}. I am sure I can handle the job, just want to know if there are any suggestions in the areas I am concerned about. Also, While I am in there is there any other economical parts I should change?
Air is fine. You should only need about 80psi to do the job and that can be regulated by the leak down tester or other setup you use. DO NOT use your direct full air from the compressor. You need to regulate it, just like when you paint. Too much air in the cylinder will allow the engine to rotate if it's not exactly on cylinder TDC so using less is better. Each cylinder will have to be on it's TDC to do this. Once you get it on a couple it'll become easier. Also, once the cams are out, the valves will be closed and you don't need to worry too much about TDC on each cylinder but DO have to make sure there's enough air in the cylinders to keep the valves closed when removing the keepers and springs.
Changing springs at the same time is easy because you have to remove them for the seals anyway. This is the time to do it. I'm a Comp or Crane guy myself, but Motorcraft will be fine if you're staying stock.
Camshaft timing is critical but not hard. The key is knowing where #1 TDC is and lining everything back up when you go back to install them. There are a few good videos on how to degree a cam (you shouldn't have to go that far
View: https://www.youtube.com/watch?v=jFOZhV1tFyE
). You'll need to know how to get the crank at #1 and install each cam accordingly. Crank and cam gears have marks and the chains do to (usually a dot/paint or other mark) to index them. However, you may not see the chain mark due to mileage. You can make your own simple marks on the chain for reference, but if the engine has high mileage, I'd replace them with new chains and guides.
The biggest thing I'd say is be patient. If this is your first, take the time to be thorough. Keep ALL cam caps and parts in order. DO NOT mix them up. Set an area so you can lay out the parts as you take them off and put them back in the same place. You will be working under the hood and running into objects that may get in your way a bit, but it's not impossible to do. If you're really unsure, removing the heads from the engine would be less stress, but a lot more work, and, you'll still have to set the timing chains correctly. It's all up to you.
