- Sep 6, 2004
- 21
- 0
- 1
My 1993 5.0 has a pretty bad stumble. I pulled for codes. Got 94 and 44 which is expected as I have GT40p heads. Did the cylinder balance test and got code 60. Checked fuel pressure and noticed my pressure was low and would not hold after key off. Changed fuel pump. Fuel pressure is at 42PSI. checked all cables and plugs and their all good. Cap and rotor is good. Pulled for codes again and I got code 90 but engine still stumbles. Took for test drive and during acceleration on top of the stumble it sounds like a ping. Re ran for codes and I got code 60 again. I am thinking a bad injector on number 6. Anywhere else I should check.
