Engine Stutter
Drummer4Life
23
K-Vages NC
I have a 88 GT 302. I just bought the car with trouble (stutter/Lose of power). It currently has an MSD and an Accel coil and wires. I replaced the plugs from old Motorcrafts and i just installed standard Autolite plugs. This fixd the issue. The car ran amazing.
After driving no more then 50 miles I am back to where i started. I disconnected the MSD to eliminate that from being the problem and checked all the wires at the diributor cap side (they all fired).
I went to buy some new plugs again (planing to get a better quality plug) and I told the guy about the MSD and Accell coil. he pulled the coil up on the computer and it isnt shaped (doesnt look the same) as the one i have installed.
So, i am guessing either the plugs (Standard Autolite) were cheap and could not hold up to the fire the MSD and coil are putting out or the coil is the problem. I havent installed the new plugs yet (Double Platium Autolite). I will install them tonight.
Any help???
Well most likely no ones going to give me any advice here however i am going to continue to update this post, vent, etc...
So tonight I did a compresion check. All cylinders are almost exactly the same. Idle reading at around 90. I am considering taking it in and getting diagnostices done. Im hoping that will get me in the right direction.
So yet again im going to finish with a question hoping someone will pike in and ask something or give some kind of advice. New coil, new plugs, wires, new distributor cap.....what else should i check/replace?
I had a similar problem with my 91 5.0 when I first bought it. I did plugs, and then wires. It turned out the wires were the issue. Hope you get it figured out.
Does it happen all the time or just under WOT? What rpms?
I think the best place for you to start would be to pull codes from the computer. Even though there is no check engine light there still may be error codes stored in the computer. Search this forum for how to do this with a paper clip....i do it all the time very simple and quick. No diagnostics tools necessary. Secondly...the standard autolite plugs are the BEST....i know that you may think that a less than 2 dollar plug is the best for a Hi-perf application....but a lot of guys on this forum, myself included, swear by them. pull codes...leave those plugs in there and let us know what you come up with.
Thanks for the info guys. Its been a real help because at time i feel like just givingup on this POS! :) However, I just pulled the codes. They are as follows:
Flicker,
3, pause, 4, pause, 3, pause 4, pause,
1, pause,
Im guessing (because this is my first time) the code is 34 and that the 1 was the a break between the two sets but im not sure. What is code 34? ISC Solenoid?
:SNSign:
This code depends if you completed the key on engine off diagnostic test or the key on engine running test. If it was the KOEO then code 34 trips for EVP sensor voltage out of rang...too high. This is the electromagnet that controls the operation of the EGR valve. The white sensor on the back of the EGR valve. If the code came up in the running test then 34 is for EGR valve opening not detected. Check the operation of the EGR valve using a supplied 10" of vacuum. You should also remove it, check the diaphragm for cracks or leaks, then check the pintle for excessive carbon build up. Clean the whole thing and reinstall it. Also check the vacuum supply hose to the EGR to check for any leaks or cracks.
All the emission **** has been disabled from what i can tell. On the EGR spacer the 2 vacumm hoses have been pluged with bolts. Is this something i should be worried about? Maybe i should provide a picture of this for further review.
Do you think the ERG could be causing this issue with lose of power, sputter, etc...
Code 34 Or 334 - EGR voltage above closed limit - Failed sensor, carbon between EGR pintle valve and seat holding the valve off its seat. Remove the EGR valve and clean it with carbon remover. Prior to re-installing see if you can blow air through the flange side of the EGR by mouth. If it leaks, there is carbon stuck on the pintle valve seat, replace the EGR valve ($85-$95).
If the blow by test passes, and you have replaced the sensor, then you have electrical ground problems. Check the resistance between the black/white wire on the MAP/BARO sensor and then the black/white wire on the EGR and the same wire on the TPS. It should be less than 1.5 ohm. Next check the resistance between the black/white wire and the negative battery post. It should be less than 1.5 ohm.
Note that all resistance tests must be done with power off. Measuring resistance with a circuit powered on will give false readings and possibly damage the meter.
Let’s put on our Inspector Gadget propeller head beanies and think about how this works:
The EGR sensor is a variable resistor with ground on one leg and Vref (5 volts) on the other. Its’ resistance ranges from 4000 to 5500 Ohms measured between Vref & ground, depending on the sensor. The center connection of the variable resistor is the slider that moves in response to the amount of vacuum applied. The slider has some minimum value of resistance greater than 100 ohms so that the computer always sees a voltage present at its’ input. If the value was 0 ohms, there would be no voltage output. Then the computer would not be able to distinguish between a properly functioning sensor and one that had a broken wire or bad connection. The EGR I have in hand reads 700 Ohms between the slider (EPV) and ground (SIG RTN) at rest with no vacuum applied. The EGR valve or sensor may cause the voltage to be above closed limits due to the manufacturing tolerances that cause the EGR sensor to rest at a higher position than it should.
attachment.php
This will affect idle quality by diluting the intake air charge
Codes 94 & 44 - AIR system inoperative - Air Injection. Check vacuum lines for leaks, & cracks. Disconnect the big hose from smog pump: with the engine running you should feel air output. Reconnect the smog pump hose & apply vacuum to the first vacuum controlled valve: Its purpose is to either dump the pump's output to the atmosphere or pass it to the next valve. The next vacuum controlled valve directs the air to either the cylinder heads when the engine is cold or to the catalytic converter when the engine is warm. Disconnect the big hoses from the back side of the vacuum controlled valve and start the engine. Apply vacuum to the valve and see if the airflow changes from one hose to the next.
The two electrical controlled vacuum valves mounted on the rear of the passenger side wheelwell turn the vacuum on & off under computer control. Check to see that both valves have +12 volts on the red wire. Then ground the white/red wire and the first solenoid should open and pass vacuum. Do the same thing to the light green/black wire on the second solenoid and it should open and pass vacuum.
Remember that the computer does not source power for any actuator or relay, but provides the ground necessary to complete the circuit. That means one side of the circuit will always be hot, and the other side will go to ground or below 1 volt as the computer switches on that circuit.
The computer provides the ground to complete the circuit to power the solenoid valve that turns the vacuum on or off. The computer is located under the passenger side kick panel. Remove the kick panel & the cover over the computer wiring connector pins. Check Pin 38 Solenoid valve #1 that provides vacuum to the first Thermactor control valve for a switch from 12-14 volts to 1 volt or less. Do the same with pin 32 solenoid valve #2 that provides vacuum to the second Thermactor control valve. Starting the engine with the computer jumpered to self test mode will cause all the actuators to toggle on and off. If after doing this and you see no switching of the voltage on and off, you can start testing the wiring for shorts to ground and broken wiring. An Ohm check to ground with the computer connector disconnected & the solenoid valves disconnected should show open circuit between the pin 32 and ground and again on pin 38 and ground. In like manner, there should be less than 1 ohm between pin 32 and solenoid valve #2 and pin 38 & Solenoid valve #1.
If after checking the resistance of the wiring & you are sure that there are no wiring faults, start looking at the solenoid valves. If you disconnect them, you can jumper power & ground to them to verify operation. Power & ground supplied should turn on the vacuum flow, remove either one and the vacuum should stop flowing.
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host)
Disabling the emissions equipment can cause the computer to go into limp mode and set the Check Engine Light. Limp mode means reduced performance and fuel economy. I recommend that you learn how the emissions & computer system work before disabling something and shooting yourself in the foot.
Here's a book that will get you started with how the Ford electronic engine control or "computer" works.
Ford Fuel Injection & Electronic Engine Control 1988-1993 by Charles Probst :ISBN 0-8376-0301-3.
It's about $25 from Borders.com see http://www.amazon.com/ . Select boo...very good, and I found it to be very helpful.
I just want to say thanks again for everyones help on stangnet. I love this site!
:SNSign:
So I removed the EGR, spacer, etc... today and to my suprise the spacer was full of carbon buildup. I am really hoping cleaning this will fix my issue.
Does the EGR suck air in the EGR or does the vacumm hose suck air from the EGR? Which direction does the vacumm move in? Should I be able to feel suction on the EGR or on the vacumm hose?
Anyway, I have cleaned everything, routed/rewired some ugly wires and now I am just waiting for the gaskets (that had to be orderd - BBK). What do guys recommend that I adjust, clean, etc... while I have everthing off? What key features should I make sure of before putting everything back on?
The EGR uses the vac line to move the diaphram in and out. After you get it all back together and test drive it, if the problem doesn't go away...try unhooking the vac line to the EGR itself (block the vac line off) and see if that helps.
Like I said, I had the exact same problem as you described along with the same code. I unhooked the vac line and the problem went away. I have since removed the EGR all together.
Yes that does help alot! If there was vacuum on the hose then thats where my problem is. I can not feel vacuum on the hose however I am unsure how much stuff was disabled in this car before i bought it.
I know the smog pump is disabled (no belt on pully) and the 2 hoses on the EGR spacer are capped with bolts. Those are the only things i have noticed disabled so far.
How noticable was the vacuum on the hose? If you were to put your tounge on it would it stick? HAHAHA I placed my tounge on the hose and could not feel vacuum.
the 2 hoses on the egr spacer just run coolant throught it, to cool the egr gasses that enter. i have heard both good and bad from disconnecting them from the egr, but they should not have anything to do with the vacuum. if they are just capped, i think you should maybe put a connector between them if u want to bypass the egr, rather than just cap. i had mine connected to bypass for a while, but i decided to put them back on after reading up on it a bit. i have no smog either, but i do get vacuum on the hose into the egr (while running, just to be clear!), verified by FINGER! good god man! maybe u can tell me what a MAF sensor is supposed to taste like? i'm getting an error on mine! :rlaugh:
I picked up my gaskets and got the trottle body, EGR spacer, and EGR back on today. Still having the same problem. I checked the vacuum lines after you guys said i should feel vacuum on the hose "by finger" and I dont feel anything on the vacuum hose going into the EGR.
The vacuum source going into the EVR (Electionic Vacuum Regulator) has a good vacuum on it however nothing after it enters into the EVR and out to the EGR. I wanted to test the power connection on the plug going to the EVR but im not sure what it should read. With a volt meter set to 12v it reads 0.03. I am a rookie when it comes to testing power like that. What should my meter be set on and what should it read?
So to move forward past the electical connection I attempted to bypass the EVR altogether and run the vacuum straight to the EGR. This made the car idle up and down from .5 to 1.5 RPM. When driving it with the EVR bypassed the car acted the same way.
At this point I am really confused. With the EVR bypassed I would think at WOT the car would work correctly if the vacuum to the EGR was my problem yet it acted the same (with or without vacuum to the EGR). The reason i say "with or without vacuum to the EGR" is because with the EVR hooked up i get no vacuum to the EGR.
:bang: What steps should i take next? Replace EGR? Replace EVR? or move on to something else and ignore what my computer is telling me?
