engine stuttering
  • Thread starter Thread starter black5.0
  • Start date Start date Apr 25, 2004
black5.0
157
enola pa
Apr 25, 2004
  • Apr 25, 2004
hey guys, im having a problem with the stang. first of all, it stalls all the time when first starting up. i have to start it 2 or 3 times before its ready to go. then while im just cruising around giving it minimum gas, the engine stutters and gets choppy likes its gasping for air or something. but when i get on the accelerator, its seems fine. my first thought was plugs, but i replaced them under a year ago. some other stuff i was thinking were plug wires or maybe some dirty fuel injectors, i really dont know . if anyone could point me in the right direction id be greatly appreciative. thanks.
cjman15
Banned
Apr 15, 2004
1,009
Fairfield, PA
Apr 25, 2004
  • Apr 25, 2004
YEAH! mine does the exact same thing sometimes.... and it makes a weird sound under the car... I have no idea what it is... I replaced my plugs less than a year ago also... I still have stock wires tho... I might change those to see if that helps...
blkstangman88
646
  • Apr 25, 2004
ever think of changing the inline fuel filter if u havnt in awhile? if ur injectors are dirty get a can of 44k, thats stuff works good
cjman15
Banned
Apr 15, 2004
1,009
Fairfield, PA
Apr 25, 2004
  • Apr 25, 2004
I've installed a new pump less than a year ago, 110lph BBK... but haven't added some 44K yet, i've been thinkin bout that... also might need to be tuned up, been running kind of rough lately
89lxvert34
64
chicago
Apr 25, 2004
  • Apr 25, 2004
dude change the TFI module on your distributor, i can almost guarantee that's causing the problem.Same thing happened to me,then i changed my fuel pump and the TFI, and it hasn't done it since
black5.0
157
enola pa
Apr 25, 2004
  • Apr 25, 2004
whats the tfi module? is it tough to replace/expensive? and whats this 44k stuff?
blkstangman88
646
  • Apr 25, 2004
44k is basicly the same stuff a shop runs through ur engine to clean the fuel system, it a consentrat u add to ur gas it it cleans the fuel system. the tfi moduel is what the wire harrness clips on to ur distribitor at. there only like two 5.5mm screws holding it on and it only costs like $20, had mine replaced but didnt even pay attention to how much it cost, but that is another idea of y u r car is stittering
black5.0
157
enola pa
Apr 26, 2004
  • Apr 26, 2004
i replaced the tfi module and theres no difference. car still stutters during normal driving sometimes and dies after being started. i really dont know where to go from here. a guy at advanced auto told me to try the fuel filter, so im going to try to replace that tomorrow. any other suggestions?
blkstangman88
646
  • Apr 27, 2004
carful with the inline fuel filter, i believe u need a certain tool to get the lines off, they dont just pull right off. ask a local mechanic about it.
black5.0
157
enola pa
Apr 27, 2004
#10
  • Apr 27, 2004
  • #10
finally fixed the problem. i pulled off the iac and there was carbon all over it. cleand it out pretty thoroughly and cleanded the throttle body and now it goes right to idle when i start it up . thanks for all your help guys.
Engine Coolant boiling in hose?
  • Teen'93stang5.0
  • Jun 3, 2026
Fox 5.0 Mustang Tech Jun 8, 2026
Mustang5L5
M
Electrical 93 5.0 No Injector Pulse
  • machinermac
  • Jul 26, 2026
Fox 5.0 Mustang Tech Aug 1, 2026
Willybill32
Engine Another no start after washing engine bay
  • bruno
  • Apr 26, 2026
Fox 5.0 Mustang Tech May 7, 2026
AeroCoupe
  • Mindseye007
  • Aug 16, 2026
Mindseye007
  • brandyn200
  • Jun 20, 2026
AeroCoupe
