engine swap please help!
  • Thread starter Thread starter saleensteven
  • Start date Start date May 10, 2006
saleensteven
  • May 10, 2006
i need some help i have a v6 mustang and i want to put in a v8 i have been looking at a 96 ford explorer 5.0. How close is that to a mustang 5.0? And if i got that motor would 5.0 mustang performance parts fit it? i could really use some help! thanks:SNSign:
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
May 10, 2006
  • May 10, 2006
yes the 5.0L parts would fit it. The explorer 5.0L engines have better heads then the 5.0L mustangs had. i believe even a better intake.
saleensteven
  • May 10, 2006
Yes i here the heads are gt-40 and maybe the intake to. What about the wiring harness the one in the explorer has the ecm in the fire wall? Will the mustang harness swap? or will the explorer harness go in the kick panel like the mustang harness?
saleensteven
  • May 11, 2006
anybody
5ive.oh
195
Rocky Mountain House, AB
May 11, 2006
  • May 11, 2006
I am not a pro mechanic but I believe you will need to swap over the flywheel/harmonic dampner off a mustang 5.0l if you plan on using the T5 trans. Do not use the trans. out of the 2.3l as the input shaft is smaller in diameter then the one from a 302 and will destroy the pilot bearing, plus the internals won't hold up as well. If you can't find a old 302 donor car why not go carbed? It will eliminate the need to mess around with ecu's and such.
5ive.oh
195
May 11, 2006
  • May 11, 2006
did a search for ya
http://forums.stangnet.com/showthread.php?t=633399&highlight=explorer+5.0
saleensteven
  • May 21, 2006
i bought the complete engine automatic trans with all the accessories and wiring. does any one on if the mustang wiring harness will plug in to all the sensors on the exploror motor and trans?
F
Freshmeat
  • May 21, 2006
You'll need the Mustang sensors if you're going to run the Mustang wiring. If you want to run the EEC-V (Explorer) harness and transmission, you'll need the EEC-V computer, as well.
To run the Mustang wiring, you'll need idle air control, throttle position, exhaust gas recirculation, O2, manifold absolute pressure or mass air flow, inlet temp, and coolant temp sensors (did I miss anything, guys?) to properly operate.
The 1997.5 and prior will list as GT-40 motors while the 1997.5 and newer will list as GT-40P. One way to tell is on the lower right corner (when looking at the exhaust ports) of the head, the standard GT-40 will have "GT", while the GT-40P will have "GTP" stamped into the heads. Ford Racing makes a header to fit the P motors specifically, but coming from someone who went the route of the P motor to get that extra power, it's not worth it. Go with the standard GT-40. The headers are another $250 invested, not to mention that it's a bitch to find long tubes.
Get the GT-40, swap cams (Explorer cams suck) and the other equipment, and call it a day. If you're running a T5 behind it, be sure to get a flywheel (as cheap as new ones are, don't waste time hunting down and resurfacing a used one) and pilot bearing. I almost forgot the pilot entirely.
Stock Explorer timing is single chain, so go ahead and get double roller equipment for a Mustang or Crown Victoria and you can swap that while you do the cam. Even a stock Mustang cam ('87-'88) is a decent upgrade. I got mine for free, only had to pay shipping.
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
T
Need help with 302 swap
  • thxmxrgx
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 24, 2026
thxmxrgx
T
Electrical V8 swap no power to anything
  • Bullittsmith
  • Sep 12, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Sep 15, 2026
Mcmahst
D
Yet another v8 swap
  • dulcimerbob
  • Sep 19, 2026
  • 4 5 6
3K
1974 - 1978 Mustang II Talk & Tech Nov 10, 2026
LILCBRA
