Engine swap question?
b653gunn
40
I've got a 96 gt i want to put a 302 in it ,i just bought a 95 k member with control arms and springs,my question is to make this work will a 95 gt wiring harness be a direct plug in or will i need to make it work,and is there anything else that might throw a wrench in the process.:SNSign:
It will not plug in. It takes alot of modification to get it done. You have to run a change some pin programming, swap to a different computer, change a few connectors, and add a few sensors. It also requires an exciter ring to be installed on the balancer. Its not a simple drop in swap.
