  • SN95 4.6L Mustang Tech
engine swap
  • Thread starter Thread starter moneypitstang
  • Start date Start date Jun 20, 2006
M
moneypitstang
9
  • Jun 20, 2006
I have a 97 mustang gt 4.6l v8 automatic tranny. I threw a rod and am looking at an engine swap....does anyone know exactly what motors will bolt up to the transmission in this car...Thanks
CanadaStang
2,093
Mb
Jun 20, 2006
  • Jun 20, 2006
Look for the newer 99-up PI engine and then swap your coil paks and fuel rails onto it.
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
Jun 20, 2006
  • Jun 20, 2006
agreed
M
moneypitstang
9
  • Jun 20, 2006
how difficult would this be?...and it would bolt directly to the transmission with no problem?... and what if i was lookin to supercharge the engine? wouldnt that put way to much stress on the transmission?
M
moneypitstang
9
  • Jun 20, 2006
and also if i decided to do that go with sohc or dohc?
Mike97gt
it doe snot
10,633
Jun 20, 2006
  • Jun 20, 2006
the 99+ SOHC motor is a direct swap, just reuse the fuel rails and coil packs and such from your current motor.
a DOHC setup is much more involved.
and there is no problem bolting to the tranny, it's a direct swap nothing will have to be changed there.
M
moneypitstang
9
  • Jun 20, 2006
so no new engine mounts or anything like that sweet...and what about supercharging it? bad idea?
CanadaStang
2,093
Mb
Jun 20, 2006
  • Jun 20, 2006
Nope no problem!!
M
moneypitstang
9
  • Jun 21, 2006
truly appreciate the help guys...i know the motor i have runs at about 215 hp stock....as for the 99 and up model...what sort of hp we talkin bout here?
CanadaStang
2,093
Mb
Jun 21, 2006
#10
  • Jun 21, 2006
  • #10
Factory rated at 260Hp. It's a nice improvement over the 97' non PI engine.
Do a search on the Jerry mod for your auto tranny.
M
moneypitstang
9
#11
  • Jun 21, 2006
  • #11
what exactly is that good for? i cant find to much on it
CanadaStang
2,093
Mb
Jun 21, 2006
#12
  • Jun 21, 2006
  • #12
It hardens up the shifts, kinda like a shift kit.
M
moneypitstang
9
#13
  • Jun 21, 2006
  • #13
so why not just go with a shift kit?
CanadaStang
2,093
Mb
Jun 21, 2006
#14
  • Jun 21, 2006
  • #14
Here's a link to some info on it as opposed to the shift kit:
http://3.8mustang.com/forum/showthread.php?p=1032115
J-mod link:http://www.tccoa.com/articles/tranny/index.html#
CanadaStang
2,093
Mb
Jun 21, 2006
#15
  • Jun 21, 2006
  • #15
Tough call as to what is actually better, the J-mod or a shift kit, depending on who you talk to. I haven't personally used either on the Mustang so I can't give any personal oppinion.
M
moneypitstang
9
#16
  • Jun 21, 2006
  • #16
hmmm... well man i appreciate the help and am pretty sure im gonna go ahead with the 99 + model 4.6 motor and supercharge it and everything...take it easy and keep helpin ppl
P
Pennywise2
Banned
May 16, 2006
1,379
#17
  • Jun 21, 2006
  • #17
The J-mod is one of the best things you automatic guys
can do and it's not that hard to do really.
billfisher
1,296
huntsville, AL
Jun 21, 2006
#18
  • Jun 21, 2006
  • #18
avoid dohc without help.
tomustang
Psychotic Member
3,434
McLean Hospital
Jun 21, 2006
#19
  • Jun 21, 2006
  • #19
Not too difficult, unbolt the driveshaft from the axle, unbolt the tranny and pull it back, unbolt the A/C off the block, unbolt the motor mounts, remove the harnesses and fuel lines and pull away, don't forget to drain the engine fluids first
Stuck
  • bshipley
  • Aug 27, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 28, 2026
squeak93
D
Yet another v8 swap
  • dulcimerbob
  • Sep 19, 2026
  • 4 5 6
3K
1974 - 1978 Mustang II Talk & Tech Tuesday at 7:10 PM
LILCBRA
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
00 4.6L V8 new clutch won’t go into gear when on?
  • Timboslice
  • Aug 15, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 21, 2026
K
351w engine swap
  • Killer351w
  • Jan 21, 2026
2005 - 2014 S-197 Mustang -General/Talk- Jan 21, 2026
Killer351w
K
