Engine + Tranny Question
  • Thread starter Thread starter 93stang351w
  • Start date Start date Aug 13, 2004
9
93stang351w
50
minneapolis,minnesnowda
Aug 13, 2004
  • Aug 13, 2004
i got a new tranny and new engine...and the engine is on the hoist, i tried putting the tranny(w/bell) on the engine while it is on the hoist and it wont go all the way in...it seems somthing it stopping it, because i know the pilot bearing is the right size....are there any special ways of doing this?? or whats the problem...should i just keep trying to put it in? thanks
88hatchblack
163
Willard, Ohio
Aug 13, 2004
  • Aug 13, 2004
try disengaging the clutch
88hatchblack
163
Willard, Ohio
Aug 13, 2004
  • Aug 13, 2004
don't mind me, i didn't notice you said WITH bellhousing
good luck!
blk92stangg
583
Hawaii
Aug 13, 2004
  • Aug 13, 2004
I have no idea if my experiences apply to trans and motor out of the car, but Ill put in my 2 cents anyways
Maybe the input shaft is too long, or the clutch is not lined up well with the pressure plate, the splines of the input shaft are not lining up with the clutch plate, or there is excessive pressure between the pressure plate and flywheel. Try spinning the output shaft with a old yoke, or even your fingers as you push in the tranny. Not sure if you can do this with the engine out, but pull the clutch fork forward somehow to relieve pressure as you wiggle the tranny into place. As it comes to the last few fractions of an inch, you can try tightening the housing bolts to pull it in all the way(not sure how safe this last one is, but it worked for me as I was on my back under the car...)
Engine Another no start after washing engine bay
  • bruno
  • Apr 26, 2026
Fox 5.0 Mustang Tech May 7, 2026
AeroCoupe
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
A
A/F ratio gauge install questions.
  • AngryH58
  • Sep 24, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 22, 2026
D
Drivetrain car still rolling while in gear and off
  • dqureshi06
  • Jan 24, 2026
Fox 5.0 Mustang Tech Jan 24, 2026
General karthief
