engine won't idle! please help
  • Thread starter Thread starter mxmattd
  • Start date Start date Nov 24, 2006
M
mxmattd
73
Orange County, California
Nov 24, 2006
  • Nov 24, 2006
i have a 66 with a 289 v8. i've never had any problems with the engine running before. i left it sitting for 3 months or more, and now it will start fine and run ok with some throttle, but won't idle (it kind of jumps between 700 and 50 rpm and then dies). could it be that the fuel has gone bad? any other ideas?
1966conv
220
  • Nov 24, 2006
Stock carb? Any mods to the car? If you keep it running long enough to let it warm up, will it stay runnng then?
Mav289
Riverside,CA
Nov 24, 2006
  • Nov 24, 2006
Had the same problem in my 289 but in the 1000 and 1500 RPM range.Turned out to be a vacumm leak.
hotrodredneck
200
Newport News Va
Nov 24, 2006
  • Nov 24, 2006
that's what it sounds like to me....there has to be a vacuum leak somewhere....check all around the carb, and all the other lines..shouldnt be too many
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Nov 24, 2006
  • Nov 24, 2006
i to think possible vaccuum leak but is it possible you have gummed up your idle jets on the carb?
M
mxmattd
73
Nov 25, 2006
  • Nov 25, 2006
well i guess it had just been too long since i ran it, the carb must have been gummed up. i put in some fuel stabilizer and after an hour the surging was greatly decreased. after driving it around for a couple hours, its back to normal (so far). thanks for the help!
L
Engine 85 GT Excessive Idle
  • lutzkecj
  • Sep 18, 2026
Fox 5.0 Mustang Tech Sep 21, 2026
86HO5.0
P
Repeated P2004 DTC trouble code with no apparent symptoms
  • poehitman
  • Mar 11, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Mar 12, 2026
poehitman
P
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
T
Help with a 95 5L crank no start
  • TheBubbaJoe
  • Nov 4, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Nov 5, 2025
AeroCoupe
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
