I have just been given a 89 hatchback with a 5.0 EFI in it. It has not been started for 2-4 years now (still haven't gotten a straight answer on that). I have replaced the battery, battery cables, Distributor cap and rotor, spark plugs (gapped to .052”) and wires. I have also changed the oil and filter and air filter. I about to change the pcv valve, brake, power steering and transmission fluids in addition to flushing and refilling the cooling system.
My problem is that I can't get the thing to stay running. It just refuses to idle. I can get it started as long as I depress the accelerator about half-way and keep it running about 2000 rpms. But as soon as it drops below that it stalls out. I have checked all electrical and vacuum lines and as far as I can tell, they are all in good condition with no leaks or loose connections. There are no fluid leaks and this car ran very well when it was last used.
What else is there for me to check? Someone told me it could be the gas, so I tried to siphon it out, but I tried for over an hour and no matter how I tried I couldn't get any out. I felt like there is something blocking the tube from going in all the way. If it is the gas, is it possible to hook the fuel pump up to a fused 12-volt power supply and disconnect the fuel filter line and let the gas run out into a container, or will the pump over-heat and break from it? And if i can do that, what size fuse and how long will it take?
Any help with this will definitely help, as this thing is really giving me a headache.
