Engine won't start!!
VelR5.0
25
SC
Guys I need some help with my 93 LX stang, please!! :( I decide to change the MSD coil and Accel ignition module yesterday with factory parts and the car started and I drove it. Today after sitting overnight the car won't start :mad: !!! I replaced the module thinking that was the problem, but no luck, so I check the ohms in the coil and it was good and also swaped it with another good one with no results!! There's power going to the coil also but no spark!! What could it be??? This is bothering me cause I didn't mess with anything else.
BTW when I did the change yesterday, after the car started the idle was inconsistent doing the same thing like when the IAC is dirty or bad.
Any suggestions will be greatly appreciated!! :(
Velez
Hmmmmmm!! When I was checking the TFI module I grabbed the distributor and moved side to side and with the keys in the ON position I could hear something activating in the engine area. Not sure if this is normal, btw it did it at certain positions like whenever the module plug was almost completely facing to the right. Thanks! Anyone else?
could have been the injectors pulsing - others have reported the same thing happening (im not sure exactly what it is but i have read from several other people having noticed the same thing).
so have you grounded (with an air gap - not actually grounded) the coil wire to see if you have spark coming out?
good luck.
good luck.
I haven't check the coil wire that goes to the cap yet, but I'm going to try it! So what could it be then if I don't get spark there? Thanks a lot for your input!! :nice:
Velez
Cranks OK, but No Start Checklist for Fuel Injected Mustangs
1.) Remove push on connector from starter solenoid and turn ignition switch on. Place car in neutral or Park. Remove coil wire from distributor & and hold 3/8” away from engine block. Jumper the screw to the big bolt on the starter solenoid that has the battery wire connected to it. You should get a nice fat blue spark.
A.) MSD or Crane ignition box if present.
B.) Coil
C.) TFI module
D.) PIP sensor in distributor
E.) ECC relay next to computer - look for 12 volts at the fuel injector red wires
F.) Fuse links in wiring harness - look for 12 volts at the fuel injector red wires
G.) Ignition switch - look for 12 volts at the ignition coil red/lt green wire.
H.) Computer
2.) Spark at coil wire, pull #1 plug wire off at the spark plug and check to see spark. No spark, possible failed items in order of their probability:
B.) Distributor cap
C.) Rotor
D.) Spark Plug wires
Two reasons:
Clue – listen for the fuel pump to prime when you first turn the ignition switch on. It should run for 5-20 seconds and shut off. To trick the fuel pump into running, find the ECC test connector and jump the connector in the lower RH corner to ground. See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html for a description of the test connector. If the relay & inertia switch are OK, you will have power to the pump. Check fuel pressure – remove the cap from the schrader valve behind the alternator and depress the core. Fuel should squirt out, catch it in a rag. Beware of fire hazard when you do this. In pinch you can use a tire pressure gauge to measure the fuel pressure. It may not be completely accurate, but you will have some clue as to how much pressure you have.
No fuel pressure, possible failed items in order of their probability:
C.) Clogged fuel filter
D.) Failed fuel pump
E.) Blown fuse link in wiring harness. Look for 12 volts at the Orange/Lt Blue wire on the fuel pump relay
F.) Fuel pressure regulator failed. Remove vacuum line from regulator and inspect for fuel escaping while pump is running.
Fuel pressure OK, the injectors are not firing.
A.) A Noid light available from Autozone, is one way to test the injector wiring.
B.) I like to use an old injector with compressed air applied to the injector where the fuel rail would normally connect. I hook the whole thing up, apply compressed air to the injector and stick it in a paper cup of soapy water. When the engine cranks with the ignition switch on, if the injector fires, it makes bubbles. Cheap if you have the stuff laying around, and works good too.
a.) Pull an injector wire connector off and look for 12 volts on the red wire when the ignition switch is on.
b.) No power, then look for problems with the 10 pin connecter (salt & pepper shakers at the rear of the upper manifold).
c.) No power and the 10 pin connections are good: look for broken wiring between the orange/black wire on the ECC relay and the red wire for the black 10 pin connector.
4.) Spark & fuel pressure OK.
A.) Failed IAB (no airflow to start engine). Press the throttle ¼ way down and try to start the car.
C.) Engine ignition or cam timing off: only likely if the engine has been worked on recently).
HO & 351W 1-3-7-2-6-5-4-8
Non HO 1-5-4-2-6-3-7-8
I found the problem and was something very simple!! :nice: One of the terminals in the module it wasn't going inside the pick up coil connector, so no spark whatsoever. Thanks a lot to those who replied to me willing to help :flag: !!
Velez
