Enging lifting help!
  • Thread starter Thread starter Andy00018
  • Start date Start date Mar 5, 2004
A
Andy00018
46
Long Island, NY
Mar 5, 2004
  • Mar 5, 2004
Hello, I've been searching around the site a little bit and been readiing up on lifting out my engine. I've read that I can bolt the lift to the front and back of the heads although I dont seem to have threads on the back of the drivers side head and on the passenger side I have metal coolant pipe I believe running past and can't tell if theres anything there. My quesiton really is can I bolt the lift directly to the lower manifold?? I've seen the EFI lift plates but dot really want to spend another $40-50 plus i need it by sunday. I dont see why it can be bolted to the lower because thats basically what the EFI plates do? Does anyone agree or disagree? Thanks
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Mar 5, 2004
  • Mar 5, 2004
The heads are identical front and rear - the same 3 threaded holes that are on the front of the heads for the accessory brackets are on the back. You just need to locate them. A grade 8 bolt should work in those. Don't you have the factory hooks bolted to the exhaust manifold bolts on number 4 and 5 cylinders?
A
Andy00018
46
Long Island, NY
Mar 5, 2004
  • Mar 5, 2004
Dont have the Factory hooks, I'm positive i dont have the bigger thread or accesory bolt thread in the back of the drivers side head, I dont know if it makes a difference but I'm not sure if there E7's, the guy that had the car before me said it had "fresh heads" and when i asked him what kind of heads it had he wasnt sure.
Progress Thread finally tuning (and more)
  • JD1964
  • Apr 1, 2026
  • 15 16 17
7K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Today at 6:59 PM
JD1964
P
Engine Mysterious coolant leak at back of engine
  • palerider94
  • Jan 18, 2026
Fox 5.0 Mustang Tech Jan 19, 2026
AeroCoupe
A
Discussion on mild budget build/ top end
  • Acesario
  • Feb 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 23, 2026
General karthief
O
Sooty/Oily Front Engine & Pulleys
  • ozenator
  • Jun 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 22, 2026
Blackhawkxx
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
