  • SN95 4.6L Mustang Tech
ERROR#2
  • Thread starter Thread starter rw98gt
  • Start date Start date Apr 30, 2008
R
rw98gt
68
peabody, ma
Apr 30, 2008
  • Apr 30, 2008
:SNSign: ok,
today i went to circut city to buy one of those cassett due-hickies to hook-up
my M-p3 player through my factory radio. now when i put the cassett into
the radio the radio showes ERROR #2 (what the hell is that!) and will not play the cassett only the radio. has anyone had a similar problem or the same problem?
danongentry
Denton, TX
Apr 30, 2008
  • Apr 30, 2008
Try pushing the button that selects which side of the tape gets played. I used to have the same sort of problem on my POS chrysler. I guess the cassette thing only puts out a signal on one side and if your tape player reads the other side it throws the error signal.
rabidscoobie
616
12
48
College Station,TX
May 1, 2008
  • May 1, 2008
Yup,did the same thing in my truck,I just went and bought a FM thingy,I tune to a radio station then tune the fm thing to the same station,and I have my mp3.
J
Jbauer
506
  • May 1, 2008
or it could be broken. I had the same problem- i tried another tape with 2 sides and it still didn't work
How do those FM thingys work, and how much do they run for? I heard they're worse than the cassette and have poor quality?
COramprat
...I can take it. I think.
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
May 1, 2008
  • May 1, 2008
rw...sounds like it isn't seeing the adapter as a valid device. Maybe try cleaning the adapter.
I have one of those FM modulators. It is OK but every now and then you get a lot of static. Mine has 3 presets so I just hit one that clears it up a bit but it never really goes away. This is on the Dynex brand from Best Buy.
R
rw98gt
68
peabody, ma
May 1, 2008
  • May 1, 2008
well i talked w/a friend to day and he told me to get one of those FM modulators.
he also told me to remove the antena for improoved reception of the modulator,
i said what about the radio he replied who cares you have all your MP3's.
i was thinking of changing my head unit but i think that i would have to change the whole system and i realy don't waunt to do that.
rabidscoobie
616
12
48
College Station,TX
May 1, 2008
  • May 1, 2008
I had the iriver brand,with 3 presets and I never have gotten static.
And if you replace the head unit there is no need to replace the entire system.I have a Kenwood now with built in cross overs and a usb port for using a thumb drive as a mp3 player now.To use an after market head unit with the 460 system all you need is the correct harness to interface with all the factory amps and speakers,since my HU has built in cross overs I get a better sound then using the factory HU.But without cross overs it sounds horrible.
R
rw98gt
68
peabody, ma
May 1, 2008
  • May 1, 2008
i didn't know that they came out w/a harness for the mach460. can i use any head unit and where do i find the harness? thanks,
ron. :SNSign:
rabidscoobie
616
12
48
College Station,TX
May 1, 2008
  • May 1, 2008
ron. :SNSign:
There is one,Its from Metra.I had this HU in my 01 gt then I got the 04 mach and kept my system to put in it,I had to buy another Metra Harness for the 04 model.Bestbuy can order them but I got mine from a local sound shop.Circuit City can get them also,they run about $20.Just call best buy and tell them you need a Wiring Harness to integrate Mach460 amps and speakers with an aftermarket HU for your year model stang...most likely they will have to order it.Hmmm just remembered for some reason best buy said they couldnt order it this last time but I think the guy was new...Circuit City said it wouldnt be a problem.Or try your local sound shop,but they always want more for them.
R
rw98gt
68
peabody, ma
May 1, 2008
#10
  • May 1, 2008
  • #10
thanks, i'll try that.
A
Resolved 03 GT Parasitic Draw Fuse 26 (PCM)
  • Antrix
  • Mar 22, 2025
SN95 4.6L Mustang Tech Mar 24, 2025
89ripper
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
79-86 Mustang Instrument Voltage Regulator (IVR)
  • sparkylawdog
  • Sep 30, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 16, 2024
Rcdgl
R
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
