ET streets with radial fronts???
BlackO3GT
54
If i go with the et streets rear with it be bad to mix them with my skinny radial fronts?? people told me that its bad to mix them.
plus i have no swaybars front or rear.
Quite a few people do it. They say it will sway on the big end, especially the faster you go. And with no front sway bay, I could only assume it would sway more. Most say you will get used to it after a couple passes. I thought about doing it several times, but I think I will end up getting big and skinnies eventually for track wheels. But many run regular radials up front and get some rear track wheels with et streets. Just take it easy the first couple passes to get the "feel" for it. Most tire companies will not recoomend it though
I run e/t streets with my regular street radials on the front. At anything below 20 psi, it starts to sway petty good at the big end. Two hands on the wheel are a must but it's drivable. I can't say what it would be like with radial skinnys though.
