Et Streets
  • Thread starter Thread starter snoboardcore
  • Start date Start date Sep 12, 2005
snoboardcore
276
New Hampshire
Sep 12, 2005
  • Sep 12, 2005
Hey guys im looking into the mickey thompson et streets. I have a 1990 mustang lx 5.0 and was wondering whats the biggest tire i could fit in there with out having to modify anything. Thanks in adavance.
Black 93 Fox
1,995
Vancouver,Washington
Sep 12, 2005
  • Sep 12, 2005
Biggest you can fit is a 275 and you might have to remove the quad shock depending on if your lowered and what not.
Daniel50
716
Discovery Bay, CA
Sep 13, 2005
  • Sep 13, 2005
to fit a 275 you will have to remove the quad shocks
snoboardcore
276
New Hampshire
Sep 18, 2005
  • Sep 18, 2005
yea i dont wanna remove anything also what size should i get the ones im looking at say the size like 26x10.x15 what size tires should i be using? thanks in advance
M
MatthewP
355
Calgary, Alberta
Sep 19, 2005
  • Sep 19, 2005
26x10.5-15LT ET Streets would be a good choice for you. These tires have an 8" tread and fit easily on a fox3 car with 15x8 wheels. You can give the tubes a miss as well - they're not going to spin on the rims.
I run 28x10.5 ET Drag on my '90 LX, but I have the quad shocks removed and Steeda weight jacker lower control arms with the back of the car jacked up a fair bit for clearance. 28x10.5 ET Drag are similar in dimension to 28x12.5 ET Street, or just about the same width as 26x11.5 ET Street.
-Matthew
Anthony85stang
43
Meriden, CT
Sep 19, 2005
  • Sep 19, 2005
Yeah youd wanna run the 26x10.5 et streetsi have the 28's on mine and i had to roll the fenders and the quad shocks are removed. Hooser also makes a quicktime pro dot that fairly decent for cheaper i belive. I personally like the hoosiers better i have to burn the MT's pretty good to get them not to spin.
M
MatthewP
355
Calgary, Alberta
Sep 19, 2005
  • Sep 19, 2005
On a cold track, like it is every day in Calgary, you do have to burn the M/T tires hard. Something like 8-10 seconds in the box. If they are not good and smokey, they won't hook on a cold track.
I found this was the case even with L4 compound ET Drags. I kept fooling myself thinking that the stickier compound would not require as hard of a burn out, but when I stepped the burnout up to 8-10 seconds in 2nd gear, I went from crappy 1.75 or so 60's to 1.56 60's.
Good luck with your choice.
-Matthew
Glad to be here
  • josep4
  • Aug 7, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 18, 2026
DadLife0724
J
Low RPM jerking
  • Justinkins
  • Jul 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 11, 2026
fasterthangas
F
305-45-17 tires on Pony wheels (17")?
  • TTSaleen
  • Mar 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 25, 2026
TTSaleen
M
Rim suggestions
  • mason5.0
  • Sep 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Qtrhrse23
M
15" Tire question
  • mcapozza
  • Aug 5, 2024
1996 - 2004 SN95 Mustang -General/Talk- Aug 10, 2024
