EVERYTHING I need to replace rotors/drums/pads/shoes?
iamadonut
122
lax
Hey everyone,
I just bought new rotors, drums, pads and shoes for my 1970 coupe.
My question, what else do I need to replace all the above? Gaskets, bolts, special tools, etc.? I'm a total newbie here and after looking through the Haynes manual it seems like I'm missing a few parts, but I just can't figure out exactly which ones.
The pads, shoes, etc. didn't come with any fasteners or anything. If you need a photo of anything to determine what else I need, I can post those, too.
Also, after I install anything, do I need to use brake cleaner on all the parts first? Or should I use brake cleaner before installing anything?
Thanks in advance
Ian
Clean everything after you get it apart. Clean the backing plates. Lube the spots on the backing plates where the shoes rub against them. Buy new spring and hold down kits. Buy two new tools, one is the tool that installs and removes the cups on the hold down springs, and the other is the tool for removing and installing the springs mounted on the top post. They are available at Autozone for barely ten bucks for the pair.
The drums and rotors can't be turned anymore, and the pads and shoes are completely worn down. Not exactly very safe. :)
Should I just replace the springs, retainers, etc. while I'm in there? I dont know the last time they've been replaced. Maybe I can take a photo and see what you guys think...
Also, if I buy a 10x2 brake drum will that fit if the one on the car is 10x1 3/4? Or is there more involved in changing the drum size?
Lastly, which tools do I need exactly? I was looking through Kragen.com and they have a million different brake tools...
Thanks!
Ian
