Code 21 – ECT sensor out of range. Broken or damaged wiring, bad ECT sensor.
Note that that if the outside air temp is below 50 degrees F that the test for the
ECT can be in error.
The ECT sensor has absolutely nothing to do with the temperature gauge. They are
different animals. The ECT sensor is normally located it the passenger side front of the engine in
the water feed tubes for the heater.
The ACT & ECT have the same thermistor, so the table values are the same
ACT & ECT test data:
Use Pin 46 on the computer for ground for both ECT & ACT to get most accurate
readings.
Pin 7 on the computer - ECT signal in. at 176 degrees F it should be .80 volts
Pin 25 on the computer - ACT signal in. at 50 degrees F it should be 3.5 volts. It is
a good number if the ACT is mounted in the inlet airbox. If it is mounted in the lower
intake manifold, the voltage readings will be lower because of the heat transfer.
Voltages may be measured across the ECT/ACT by probing the connector from
the rear. A pair of safety pins may be helpful in doing this. Use care in doing it
so that you don't damage the wiring or connector.
Here's the table :
68 degrees F = 3.02 v
86 degrees F = 2.62 v
104 degrees F = 2.16 v
122 degrees F = 1.72 v
140 degrees F = 1.35 v
158 degrees F = 1.04 v
176 degrees F = .80 v
194 degrees F = .61
Note that all resistance tests must be done with power off. Measuring resistance
with a circuit powered on will give false readings and possibly damage the meter.
Ohms measures at the computer with the computer disconnected, or at the sensor
with the sensor disconnected.
50 degrees F = 58.75 K ohms
68 degrees F = 37.30 K ohms
86 degrees F = 27.27 K ohms
104 degrees F = 16.15 K ohms
122 degrees F = 10.97 K ohms
140 degrees F = 7.60 K ohms
158 degrees F = 5.37 K ohms
176 degrees F = 3.84 K ohms
194 degrees F = 2.80 K ohms
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds
CODE: 31 (KOEO) - EVP circuit below minimum voltage. Vref (5 volt reference
voltage supplied by the computer) missing or broken wire or bad connection in circuit.
Use a DVM to check for 5 volts on the orange/white wire. If it is missing, look for +5 volts
at the orange/white wire on the TPS or MAP sensor located on the firewall near the center
of the car. Use the black/white wire for the ground for the DVM.
With the sensor removed from the EGR and still connected, press the plunger and watch
the voltage change on the brown/lt green wire. Pull the passenger side kick panel
and measure the voltage at the computer. You will need to remove the plastic cover over
the wires and probe them from the backside. A safety pin may prove very useful for this
task. Use pin 27, EVR input (brown/lt green wire) and pin 46, signal ground (black/white
wire) to measure the voltage. The orange/white wire is Vref and should always be 5 volts
-/+ .25 volt. Be sure to measure Vref at the EGR sensor to rule out any broken wires or bad
connections.
Code 33 - Insufficient EGR flow detected.
Look for vacuum leaks, cracked
vacuum lines, failed EGR vacuum regulator. Check to see if you have 10” of vacuum at the
EGR vacuum connection coming from the intake manifold. Look for electrical signal at the
vacuum regulator solenoid valves located on the rear of the passenger side wheel well.
Using a test light across the electrical connector, it should flicker as the electrical signal
flickers. Remember that the computer does not source any power, but provides the
ground necessary to complete the circuit. That means one side of the circuit will always
be hot, and the other side will go to ground or below 1 volt as the computer switches on
that circuit.
Check for resistance between the brown/lt green wire on the EGR sensor and pin 27 on
the computer: you should have less than 1 ohm.
Stang&2Birds (website host)
http://www.veryuseful.com/mustang/tech/engine/images/88-91eecPinout.gif
Fix the code 31 and the code 33 will probably go away. The sensor isn't sending the
proper signal to the computer, so it thinks there is no EGR flow.
Code 41 or 91 - O2 indicates system lean. Look for a vacuum leak or failing O2 sensor.
The computer sees a lean mixture signal coming from the O2 sensors and tries to
compensate by adding more fuel. Many times the end result is an engine that runs
pig rich and stinks of unburned fuel.
The following is a Quote from Charles O. Probst, Ford fuel Injection & Electronic Engine control:
"When the mixture is lean, the exhaust gas has oxygen, about the same amount as the
ambient air. So the sensor will generate less than 400 millivolts. Remember lean = less voltage.
When the mixture is rich, there's less oxygen in the exhaust than in the ambient air,
so voltage is generated between the two sides of the tip. The voltage is greater than 600
millivolts. Remember rich = more voltage.
Here's a tip: the newer the sensor, the more the voltage changes, swinging from as
low as 0.1 volt to as much as 0.9 volt. As an oxygen sensor ages, the voltage
changes get smaller and slower - the voltage change lags behind the change in
exhaust gas oxygen.
Because the oxygen sensor generates its own voltage, never apply voltage and
never measure resistance of the sensor circuit. To measure voltage signals, use an analog
voltmeter with a high input impedance, at least 10 megohms. Remember, a digital
voltmeter will average a changing voltage." End Quote
Measuring the O2 sensor voltages at the computer will give you a good idea of how well
they are working. You'll have to pull the passenger side kick panel off to gain access t
o the computer connector. Remove the plastic wiring cover to get to the back side of the
wiring. Use a safety pin or paper clip to probe the connections from the rear.
The computer pins are 29 (LH O2 with a dark green/pink wire) and 43 (RH O2 with a
dark blue/pink wire). Use the ground next to the computer to ground the voltmeter.
Most of the common multimeters have a resistance scale. Be sure the O2 sensors are
disconnected and measure the resistance from the O2 sensor body harness to
the pins on the computer.
Note that all resistance tests must be done with power off. Measuring resistance with
a circuit powered on will give false readings and possibly damage the meter. Do not
attempt to measure the resistance of the O2 sensors, it may damage them.
The O2 sensor ground (orange wire with a ring terminal on it) is in the wiring harness
for the fuel injection wiring. I grounded mine to one of the intake manifold bolts
