Exhaust hitting control arm....help!
jmd2914
937
Napa, California
alright, on the drivers side back where my exhaust goes up over the axle the pipe is hitting against the control arm when i drive. and its really starting to bug me not to mention sound really bad when i drive. im about ready to just cut of my tails and weld on turndowns unless anyone has any suggestions. if so please tell me.
Did you recently install a cat back system? If so, loosen it right behind the muffler, rotate the tailpipe a little, and tighten it down. Check to make sure that the muffler is parallel with the ground too...
if you've got any type of aftermarket mufflers, my vote is for teh turndowns :nice:
other than that, check your exhaust hangers, there's one mounted with the tranny on the crossmember, one on each muffler, and one on each tailpipe. if one or more of those are not connected, the tension in the connections will flex the entire system, my right tailpipe was rubbing on my tire for a while :rolleyes:
i bought a flowmaster american thunder catback but i yanked them out and had race bullets welded in, so i cant rotate the pipe. so im thinkin i might just put dumps on, however im not sure how its gonna look cuz the body kit had holes for tailpipes in the back. anyone have any suggestions?
