Exhaust leak problem
  • Thread starter Thread starter 93steeda
  • Start date Start date Feb 4, 2004
9
93steeda
50
North Carolina
Feb 4, 2004
  • Feb 4, 2004
I got a set of Mac shorties used and put them on and have a bad leak. I put new gaskets on and tightened the bolts tight. Its only the passenger side leaking. I was wondering if I could double up on the gasket and maybe seal it better or would this be a bad idea?
Jo_885o
422
Clint. Twp, Michigan
Feb 4, 2004
  • Feb 4, 2004
Just get a thicker gasket preferably a copper one, had the same problem.
9
93steeda
50
North Carolina
Feb 4, 2004
  • Feb 4, 2004
Where do you get the copper ones at?
J
jef0509
83
New Jersey
Feb 4, 2004
  • Feb 4, 2004
I had a set of Mac equal lengths on the car when I got it and they loosened up over time and warped. They never sealed properly after that. I heard they also may leak at the collector. Check out all those things, those are the cheapest, if all else fails get a set of BBK, they have thicker one piece flanges, even used they are less likely to give you probs, atleast in my opinion...but good luck with the MAC's, try to make them work before you spend money
Jo_885o
422
Feb 4, 2004
  • Feb 4, 2004
Go to summitracing.com and go to exhaust and u will find 'em only 2?.?? something dollars.
9
93steeda
50
North Carolina
Feb 4, 2004
  • Feb 4, 2004
Thanks for the info, I'll try different gaskets.
88stangmangt
2,332
Stafford,VA
Feb 4, 2004
  • Feb 4, 2004
u prob didnt get them sealed good drop it back down scrap the block with a razor get it all flat a smooth.
P.S. dont double up on gaskets because that is all the less thread you get into the heads.
93VertLX
667
Dayton, OH
Feb 4, 2004
  • Feb 4, 2004
I had the same problem with my mac shorties, I just took them off and did it again with new gaskets, and it worked fine that time.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Feb 5, 2004
  • Feb 5, 2004
Has anyone tried heating the pipe with a torch and then tightening the bolts? Since ith is heat that causes the pipe to twist, maybe heating it read hot and then tightening the bolts will pull it back into shape.
88stangmangt
2,332
Stafford,VA
Feb 5, 2004
#10
  • Feb 5, 2004
  • #10
ya but it doesnt get that hot from the heads.
D
Exhaust Difficulty of fixing exhaust leak at manifold
  • dqureshi06
  • Aug 27, 2026
Fox 5.0 Mustang Tech Aug 28, 2026
General karthief
W
2016 Mustang GT fuel tank leak
  • Waynetk16
  • Oct 8, 2026
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Oct 9, 2026
gkomo
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
D
Electrical Weird door wiring issues
  • Dakar09
  • Oct 20, 2026
Dakar09
D
R
bbk shorty header to mid pipe gasket
  • randyyy
  • Sep 29, 2025
1996 - 2004 SN95 Mustang -General/Talk- Sep 29, 2025
randyyy
R
