  • SN95 4.6L Mustang Tech
exhaust manifold stud.....HELP!! (pics)
  • Thread starter Thread starter four.six
  • Start date Start date Aug 5, 2005
F
four.six
443
Corpus Christi, TX
Aug 5, 2005
  • Aug 5, 2005
i need a new pass side manifold stud.. the one that is on there is all messed up from a nut being cross threaded on it. the problem is, i cant get that ****ing stud out . is there a tool for this?? thanks for the help....
mustang70
2,445
San Diego
Aug 5, 2005
  • Aug 5, 2005
This might be a little big for your application.
http://www.sears.com/sr/javasr/prod...0&vertical=TOOL&pid=00904458000&bidsite=CRAFT
You're really worrying me about doing my mid pipe this weekend.
jeff1414
447
Sacramento
Aug 5, 2005
  • Aug 5, 2005
I think craftmans makes some stud removal kit..Never tried it..check out sears
stangman16
640
San Antonio, TX
Aug 5, 2005
  • Aug 5, 2005
There really isn't any worry to it, just make sure you do it yourself. As always said - "if you want something done right, you better do it yourself."
four.six had a hot rod store here in San Antonio do it - and they did a poor job. Appears they must have crossed threaded it using an impact wrench, I'm guessing that they did not screw the nut on enough before applying the impact. We spent 5 minutes with the sears tool for removing the nut, it worked great. Just gotta get that stud out now, before installing a new stud and completing this issue.
billfisher
1,296
huntsville, AL
Aug 5, 2005
  • Aug 5, 2005
stud removal
the process for removing a stud or broken bolt is to weld a bolt to it if it is long enough. if it is broken at or below the surface a screw extractor is necessary. you have to drill it straight in. if the stud is 5/16 for example a 1/8" extractor is used. the problem is the drilling has to be deep enough to engage the extractor. the hole also needs to be straight enough to avoid drilling to the head. this sounds real bad. without seeing it you will need to raise the block high enough to drill it.
billfisher
1,296
huntsville, AL
Aug 5, 2005
  • Aug 5, 2005
forget i said that. have you tried to jam nut it? can you stack washers and use it? last resort... weld nut on it. that will ruin it.
billfisher
1,296
huntsville, AL
Aug 5, 2005
  • Aug 5, 2005
what about using a propane torch to heat the aluminum ear around it. use kroil. i do this stuff every day at the plant. It SUCKS.
road rage
433
R.I.
Aug 5, 2005
  • Aug 5, 2005
Try useing a rethreader
lazerred02
190
FT Stewart, GA
Aug 6, 2005
  • Aug 6, 2005
Just rethread that stud, it should work just fine and it is easy as hell to do.
helty
some Ukrainian's enjoying a handjob via my credit
Mar 30, 2005
1,461
Baltimore, MD
Aug 6, 2005
#10
  • Aug 6, 2005
  • #10
yeah those studs are a *****. took us about an hour per stud (trying several different methods and quitting a few times out of frustration). finally using a **** load of pb blaster and the two nut method, we got em out. very frustrating though
mcmmotorsports
689
Danbury, CT
Aug 6, 2005
#11
  • Aug 6, 2005
  • #11
You guys are making this WAY too difficult. All you need is two nuts. Thread one nut about half way, then screw the other nut to the stud. Take two wrenches, hold the top nut and tighted the bottom one to it. Then, just loosen the top nut, it will back right out.
COBRA90GT
Mustang Master
Sep 22, 2001
6,654
HOCKEYTOWN ® , MI
Aug 6, 2005
#12
  • Aug 6, 2005
  • #12
^ What he said, the "double nut" method works.
F
four.six
443
Corpus Christi, TX
Aug 6, 2005
#13
  • Aug 6, 2005
  • #13
i cant even get a one nut on there... did u see the threads???
mcmmotorsports
689
Danbury, CT
Aug 6, 2005
#14
  • Aug 6, 2005
  • #14
I saw them, but start one on it and impact it up there.
F
four.six
443
Corpus Christi, TX
Aug 6, 2005
#15
  • Aug 6, 2005
  • #15
that might just work... i will try that and let u know. thanks man.
forpit2000gt
2,490
Columbia, SC
Aug 6, 2005
#16
  • Aug 6, 2005
  • #16
it does/will work.
J
Exhaust manifold to Y-pipe nut & stud dimensions?
  • joeybuddy96
  • Jul 7, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jul 9, 2026
joeybuddy96
J
M
Help! 2003 GT misfire when hot
  • Modular03
  • Feb 10, 2026
SN95 4.6L Mustang Tech Feb 13, 2026
Mustang5L5
D
Please help with vacuum lines
  • Dawgs000082
  • May 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 10, 2026
Dawgs000082
D
  • AeroCoupe
  • Aug 2, 2026
AeroCoupe
C
Shifter lever arm issue
  • chris1993
  • Jan 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 24, 2026
Rcdgl
R
