Exhaust Manifolds Bright Red!!
I just put back on the upper and lower intake manifolds after finding the lower to head bolts loose. I warmed up the engine to set the idle and initial timing. I did the KOEO with a code 11 and went to do a KOER and the car revved to 2500 which seemed high. I looked down and noticed that both exhaust manifolds were glowing bright red. I have never seen this before so I turned the car off to cool. I was wondering if this is normal.
I sat my initial base timing to 14 which is what is was before taking the intake off. I am guessing I set my TDC correctly or the car would not start at all. After setting the idle I went to take the car around the corner. When I pulled out the brakes took all I had to stop and the car started running horrible so I pulled back in and started to run the KOEO and KOER test. When I put the car KOER and car revved to 2500 to do the test usually it is around 1500 which I though was weird that is when I looked and saw the manifolds. I will check both the timing and for vaccum leaks.
