  • SN95 4.6L Mustang Tech
exhaust question
  • Thread starter Thread starter Ryan441
  • Start date Start date Apr 29, 2008
R
Ryan441
173
wintersprings, fl
Apr 29, 2008
  • Apr 29, 2008
if one of my exhaust pipes broke after the muffler would that have anything to do w/ the motor not running? one or two days after it broke the motor died.
Winters98GT
Whoop...whoop-whoop-whoop-whoop...GANGNAM STYLE!!!
1,291
224
H Town
Apr 29, 2008
  • Apr 29, 2008
no it would not. I, like many, have no pipes. There are no 02 sensors after mid pipe.
Elaborate on what problems you are having. The motor not running is not too specific
R
Ryan441
173
wintersprings, fl
Apr 29, 2008
  • Apr 29, 2008
i was driving it and the check engine light was flashing, blew some white smoke when first started, sputtering, sucked down $25 in gas w/ in 15 20 min pulled over cause it ran out. i went to start it later and it wouldnt turn over, i tried again and it turned over. trailered it home and put gas in it. started right up, shut it off and went to start it later and it wouldnt turn over
R
Ryan441
173
wintersprings, fl
Apr 30, 2008
  • Apr 30, 2008
i think its the timing chain on one side broke.
BurningRubber
1,865
24
58
May 1, 2008
  • May 1, 2008
White smoke normally indicates coolant being burned.
Possibly popped a head gasket, but that doesnt really explain the massive fuel consumption... at least not to me.
Any knocking, ticking, or anything during this process?
BobHyatt
378
  • May 1, 2008
I'd bet head gasket, leading to coolant intrusion into a cylinder, leading to a hydraulic block. Pull all the plugs and have someone hit the starter. If you get a shower, you have a gasket problem...
R
Ryan441
173
wintersprings, fl
May 1, 2008
  • May 1, 2008
i pulled all the plugs and they were all dry, but there was no coolant left in the resivour. while it was running it was knocking and sputtering.
R
rw98gt
68
peabody, ma
May 1, 2008
  • May 1, 2008
for the fuel maybe bad fuel pump. for the white smoke it could be coolent or it could be blow by (oil) oil gets by the worn ring in the pistions. how many miles on your car? if it has high milage that could be your problem.
R
Ryan441
173
wintersprings, fl
May 3, 2008
  • May 3, 2008
its got about a 100k. if its just blow by why is the motor seized. it doesnt make sense that the motor would sieze then uncieze. today i pulled the valve covers off and everything looked ok. then i got the intake manifold off and the 8th cylinder intake was filled w/ coolant. idk what to do next, pull the heads off?
New Exhaust for 408w stroker
  • SadbutTrue
  • Sep 10, 2026
1965 - 1973 Classic Mustangs -General/Talk- Sep 10, 2026
nickyb
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
SN95 4.6L Mustang Tech Oct 20, 2026
DangStitches
D
identifying smog/fuel part on 1998 GT
  • dochawk
  • Jun 18, 2026
SN95 4.6L Mustang Tech Jun 30, 2026
F
2004 Mustang GT – Fuel Pump Not Priming
  • Fayio
  • Apr 22, 2026
SN95 4.6L Mustang Tech Apr 27, 2026
n0v8or
N
Axleback installation
  • Bob Foos
  • Jun 13, 2026
2005 - 2014 S-197 Mustang -General/Talk- Jun 15, 2026
