Exhaust question
  • Thread starter Thread starter 90convertible5.0
  • Start date Start date Mar 14, 2013
90convertible5.0
  • Mar 14, 2013
Installing a new H Pipe today. When removing the old one, can I loosen up the clamp connecting the smog pump line to the H pipe and pull them apart (if so how have others managed to influence the two to separate, relief cut didn't work for me)? or do I need to just cut it off and find someone to weld it back to the new one?
Mustang5L5
Mod Dude
Feb 18, 2001
43,361
18,106
224
Massachusetts
Mar 14, 2013
  • Mar 14, 2013
Hack off the clamp connector by cutting the pipe on both sides. It leaves about a 2" gap, then slide some 3/4" heater hose over the two ends when ready to connect and then use hose clamps to secure it. A little WD-40 helps the hose slide on easier.
We've all tried to reused that clamp setup....just easier to use heater hose
90convertible5.0
  • Mar 14, 2013
After messing with it for a couple hours, that sounds a lot easier. Thanks for the help. (plus UPS guy just showed up with the new H Pipe)
84Ttop
5 Year Member
Jul 2, 2009
5,222
3,255
204
South Jersey
Mar 15, 2013
  • Mar 15, 2013
They actually sell a high temp silicon hose specifically designed for this type of application. I know that my local PepBoys carries it and it holds up much better than heater hose.
7991LXnSHO
wanna catch the space herp
7,387
2,746
194
Kearney, NE
Mar 15, 2013
  • Mar 15, 2013
+1 on the silicone hose. That close to the exhaust and before the check valve, it might get a lot of heat. Ebay has listings by the foot too. My take off replacement parts came with a chunk of the silicone hose that cleaned up like new.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Mar 15, 2013
  • Mar 15, 2013
Simpler plan: drill a 1/8" hole all the way through the pipe about 2" up from where the clamp was. Stick a 1/8" Allen wrench in the hole and then back a pair of vise grip pliers up against the Allen wrench. Vigorously apply the big hammer to the vise grips and you can make the pipe come loose. Use the same method to reinstall it and use some sheet metal screws to fill the holes.
90convertible5.0
  • Mar 15, 2013
Thanks for all the advice. I ended up chopping it and using some heater hose for the time being (this is my DD). I will be looking to replace the hose with silicone hose as soon as I can.
Mustang5L5
Mod Dude
Feb 18, 2001
43,361
18,106
224
Massachusetts
Mar 16, 2013
  • Mar 16, 2013
I've had regular heater hose on my car for 15 years....same piece. It's still fine
Sent from my iPhone 4S using Tapatalk
Fox Removing smog only questions
  • 91GTstroked
  • Sep 12, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 14, 2026
91GTstroked
New Exhaust for 408w stroker
  • SadbutTrue
  • Sep 10, 2026
1965 - 1973 Classic Mustangs -General/Talk- Sep 10, 2026
nickyb
Fox Another try for the European guy to get his first Fox
  • Schargedfox
  • Aug 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 4, 2026
DadLife0724
Cooling Jacket Pitting Idea's?
  • BoostedRed89gt
  • Aug 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 17, 2026
Mustang5L5
M
2001 v6 heater return pipe leak question
  • mnky99
  • Nov 11, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Nov 11, 2025
mnky99
M
