Explain the different cams
  • Thread starter Thread starter dstang01
  • Start date Start date Mar 29, 2007
D
dstang01
170
Vancouver, BC
Mar 29, 2007
  • Mar 29, 2007
So some of the common names Im hearing when it comes to cams are the e303, b303, f303, trickflow stage 1, 2 and 3, steeda and more.. could somebody debunk all these cams for me, maybe give a few qualities of each one and what setup they are ideal for? Thanks alot
sawbones25
1,318
Virginia
Mar 29, 2007
  • Mar 29, 2007
Cams shouldn't be selected by themselves. They need to be matched with the intake, heads, pistons, exhaust, rpm range, intended use and emissions standards if applicable.
The specs of all those camshafts you listed are available online.
www.google.com
Aryan15
236
CA
Mar 30, 2007
  • Mar 30, 2007
I have the b303, ford racing, and its just a mild cam. Pulls okay at mid to high rpms. This is with stock heads and intake.
Modular2v
3,222
23
99
oklahoma
Mar 30, 2007
  • Mar 30, 2007
it all depends on the combination. The cams you listed are a wide variety as far as specs go. The trick flow stage 3 cam is about the largest off the shelf cam you can by but unless you have the heads for is all those cams are completely worthless for your setup. To be perfectly honest, if you are running stock port/valve e7s stay with the stock bumpstick!
Fox 89’ GT 331 stroker, Trickflow upper/lower, TF#3 Cam, stuffed with forged goodies.
  • 08GT500
  • Nov 6, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 6, 2025
08GT500
J
68 Mustang with Foxbody Engine Stalling Issues - MSPNP2
  • JayV68Stang
  • Mar 13, 2025
  • Digital Self-tuning Forum
Digital Self-tuning Forum Mar 13, 2025
JayV68Stang
J
2001 roush stage 3 - sat for 5 years
  • Brando_05
  • Aug 26, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 26, 2025
Brando_05
4.6 question for those in the know....
  • LILCBRA
  • Aug 30, 2024
2K
2005 - 2014 S-197 Mustang -General/Talk- Sep 4, 2024
Adieu
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
