whats the difference in Horsepower then a 86's 5.0 HO?
as far i as know the heads are different and the intake? anything else?
mustanggt.org said:The 5.0L EFI was upgraded a massive 25 horsepower with a hotter 302 featuring a bigger intake plenum and a larger 580 cfm throttle bore (increased from 58mm to 60mm along with a revised inlet duct). Needing to correct its poor decision to change the heads for the 1986 model year, Ford realized the casting molds were gone for the pre-'86 heads. Fortunately, Ford found a solution within its truck division. The 302 trucks used a cylinder head similar in design and performance to the old wedge-type heads and, being a direct fit, the E7TE truck heads were matched to the H0 5.0L Mustangs beginning with the '87 model year. These heads featured better breathing valves, opened-up exhaust ports, and 9.0:1 CR dished-top forged pistons replacing the previous year’s flat tops. 19 lb-hr. injectors, a tuned length aluminum manifold (with better flowing runners), roller lifter cam and EEC-IV electronics system all carried over from ‘86. Stainless steel exhausts teamed up with stainless steel tubular headers improved air flow, dumping into a common collector.
8950HO said:Ford is retarded!
They put lousey heads and intake on the 5.0L stangs,(except 93-95 Cobra),and put the good factory heads and intake on the f`n 5.0L Explorers.
Bastards.![]()
ryan218 said:yeah LOL i thought of that to liek WTF the explore haas more power then my musatang![]()
my lawn mower has more power then YOUR mustangryan218 said:yeah LOL i thought of that to liek WTF the explore haas more power then my musatang![]()
mob said:alot of things have more power then your mustang...
ryan218 said:thanks. 93gtosu? where are located? ohio? and do u go to osu?
93GTosu said:yeah i go to osu i live right around campus.
