Explorer drop in Engine?
  • Thread starter Thread starter LilBerx
  • Start date Start date May 1, 2012
LilBerx
340
26
29
Logan, UT
May 1, 2012
  • May 1, 2012
What all would I need to do to swap my 86 engine with a explorer 5.0
Should i replace my motor mounts?
Will the Harness from the explorer work ok?
LarsD
2,680
119
123
Texas
May 1, 2012
  • May 1, 2012
Harness won't work. I think you need to swap most of all the external accessories, (water pump, oil pan, headers, injectors, etc). You will probably want to replace your mounts if they are worn (of course).
stykthyn
5,232
2,652
223
gainesville
May 1, 2012
  • May 1, 2012
Covered many times. You will need to swap over the mustang's complete front dress, flywheel, harnesses, heater tubes, distributor, harmonic balancer ,oil pan, cam, and new valve springs. This is a rather. Short list as you will find many things that will need to be replaced while you are in there. Oh yeah. Screw in adapter plug for the oil filter unless you keep the explorers remote setup.
M
Running rough
  • Mike3
  • Dec 31, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 1, 2026
Mike3
M
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
G
Engine PATS off pcm for 1999 Explorer 5.0 swap
  • GOvert
  • Dec 23, 2025
Fox 5.0 Mustang Tech Jun 14, 2026
GOvert
G
Electrical/engine bay harness questions
  • djj62478
  • May 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 6, 2026
djj62478
Resolved Wiring electric fan
  • cbac89
  • Aug 29, 2026
cbac89
