explorer intake vacuum line question
warriorpluto
267
monroe.LA
ok i have an explorer intake from a 2000. the upper and lower has egr luckily but when i got ready to install the upper i noticed i didnt have the little metal tree like the stock intake does at the underside of the upper intake. how do i go about hooking this up?
if it has egr, then it's a 96 or early 97 intake, not a 2000...
that's besides the point though.
you don't need the tree, just hook up your vacuum to existing vacuum lines...use vacuum t's if you need to.
one line straight from intake to fuel regulator, one to pcv valve, one to the vacuum tree, one goes to the charcoal canister, and one to the egr/tab/tad solonoids
Vacuum is vacuum: it doesn't matter where you source the vacuum from. All you have to do is match the hose sizes - don't connect a big hose to a little vacuum port and expect it to work well.
The fuel pressure regulator is the only thing that shouldn't share a vacuum line with something else. That's because if the FPR diaphragm leaks, it will spread fuel throughout the vacuum lines and devices attached to it.
Vacuum line connections:
One large vacuum line from the upper front goes to the carbon canister
One large vacuum line from the rear goes to the vacuum tree.
One small line in the front feeds the Smog pump solenoid control valves on the rear of the passenger side wheel well..
One small line in the rear goes to the fuel pressure regulator.
One small line in the rear goes to the EGR suction regulator.
One large line in the rear goes to the PVC valve.
Diagram courtesy of Tmoss & Stang&2birds - Typical Vacuum Routing for a Fox stang 5.0:
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds
(website host) for help on 86-95 5.0 Mustang wiring Mustang FAQ - Engine Information Everyone should bookmark this site.
Ignition switch wiring
Complete computer, actuator & sensor wiring diagram for 88-91 5.0 Mass Air Mustangs
Complete computer, actuator & sensor wiring diagram for 91-93 5.0 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/91-93_5.0_EEC_Wiring_Diagram.gif
Complete computer, actuator & sensor wiring diagram for 94-95 5.0 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/94-95_5.0_EEC_Wiring_Diagram.gif
Vacuum diagram 89-93 Mustangs
HVAC vacuum diagram
TFI module differences & pinout
Fuse box layout
