J joe3 New Member Dec 30, 2005 23 0 0 Sep 5, 2007 #1 Sep 5, 2007 #1 will i have to change the cam being the firing order is diffrent thanks in advance o the f150 is 5.0
MustangLX-5.0 Founding Member Dec 2, 2000 856 7 38 Lehigh Acres Fla. Sep 5, 2007 #2 Sep 5, 2007 #2 Why would you have to change the cam out if your putting in a whole different motor? That is what you meant by that? You took the motor out of an F150 and put in a 5.0 from an Explorer?
88mouse New Member Apr 18, 2007 630 0 0 Mooresville nc Sep 5, 2007 #3 Sep 5, 2007 #3 What year is the F150?
J joe3 New Member Dec 30, 2005 23 0 0 Sep 5, 2007 #4 Sep 5, 2007 #4 f150 is a 93 and it has a diffrent firing order it is not a ho firing order like the explorer and i thought it was batch fire not sefi on the f150
BlownFiveLiter have car, will race....wait, it doesn't run 15 Year Member Nov 29, 1999 3,133 18 108 Chicagoland Sep 6, 2007 #7 Sep 6, 2007 #7 If the F150 uses the non-HO firing order, then you'll need a non-HO cam in the Explorer engine. The Explorers used the HO firing order.
