Export brace install
  • Thread starter Thread starter Randy'65
  • Start date Start date Sep 9, 2010
R
Randy'65
352
Richmond, VA
Sep 9, 2010
  • Sep 9, 2010
I got an export brace, and I'm trying to figure out how to take off the existing extensions from the shock tower. Are there a couple of spot welds or something? All I can really see is gobs of what looks like seam sealer, but it's pretty hard. Or do you just leave the stubs underneath the export brace?
Az Pete
711
18
49
Panama City, Fl.
Sep 9, 2010
  • Sep 9, 2010
Yep. two or three spot welds. Once off, weld the holes filled again. Some just leave those parts on.
66er
  • Sep 12, 2010
I left mine on......
stangman16
640
San Antonio, TX
Sep 12, 2010
  • Sep 12, 2010
I sanded down the paint lightly (don't make it smooth) to find where the spotwelds were. Then I used Eastwoods spotweld remover to remove the welds. Rocked the piece back and forth (to break it loose) in case you don't cut all the way through -it's not tough.
EW 3/8in Double Ended Spot Weld Cutter
Or you can use a drill-bit, but you may find more use with this cutter later. Fairly cheap too.
Using the spotweld cutter I don't have to weld holes, I can just use filler to fill in the low spots and sand it down real quick. (no big deal either way)
tx65coupe
Sep 12, 2010
  • Sep 12, 2010
I just left mine on. Most cars I see are like that. I figured it doesn't hurt anything to leave them.
M
Too much for me to repair in my current housing situation
  • My Drama Magnet 04 Gt
  • Apr 1, 2026
  • The Welcome Wagon
The Welcome Wagon Apr 14, 2026
  • AeroCoupe
  • Aug 2, 2026
AeroCoupe
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
water pump installation questions
  • B0udreaux
  • Feb 5, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 28, 2026
General karthief
G
Intro and FB questions
  • gflat65
  • Nov 16, 2025
1965 - 1973 Classic Mustangs -General/Talk- Nov 25, 2025
horse sence
