  • 1994 - 1995 Specific Tech
External fuel pump
  • Thread starter Thread starter DavidF
  • Start date Start date Mar 11, 2004
DavidF
158
Ventura, Ca
Mar 11, 2004
  • Mar 11, 2004
I have an 95 vert. My 255lph fuel pump just took a dive. After taking the gas tank out I'm thinking about using an external pump. Has anyone done this? which pump did you use? Any tips would be appreciated.
P.S. I'm using 30lb injectors, Aeromotive reg., stock lines.
Thanx
Black70Fastback
319
Dyer, IN
Mar 11, 2004
  • Mar 11, 2004
maybe you could be the first and let us know. all the good companies, walbro, holley, carter, accel should all sell external pumps. just make sure your getting one rated for fuel injection. ya know, 255lph at 40 psi.
im converting a 33 year old car to fuel injection so im also curios. will they not over heat without the fuel in the tank cooling it?
DavidF
158
Ventura, Ca
Mar 11, 2004
  • Mar 11, 2004
Well not only that, but the 95's fuel lines enter the tank from the top so Im not sure if the pumps are good for "sucking" the fuel or "pushing".
Black70Fastback
319
Dyer, IN
Mar 12, 2004
  • Mar 12, 2004
ya know i think mine actually comes in from the top too. it just siphons to the pump which as of now is all the way on the motor for me. dont most fuel cells do this also? i would have to look to make sure but i believe mine does.
F
2004 Mustang GT – Fuel Pump Not Priming
  • Fayio
  • Apr 22, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Apr 27, 2026
n0v8or
N
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
H
Fuel starvation issues, 91 EFI to carb swap. Car dying after 1-3 gallons used. EFI tank, electric fuel pump, bypass regulator. Dual fed carb
  • hassler
  • Oct 11, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 12, 2025
nickyb
L
1997 V6 Starting issue
  • leanzik04
  • Mar 20, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Mar 20, 2026
