Extremely Weird Problem
  • Thread starter Thread starter V8_Kind_Of_Guy
  • Start date Start date Jan 12, 2010
First Prev 2 of 2
liljoe07
5 Year Member
Feb 18, 2009
1,622
363
124
Cartersville,Ga
Jan 19, 2010
#21
  • Jan 19, 2010
  • #21
Posted via Mobile Device
Were all the sensors unpluged? If not, Then they can show resistance.
liljoe07
5 Year Member
Feb 18, 2009
1,622
363
124
Cartersville,Ga
Jan 19, 2010
#22
  • Jan 19, 2010
  • #22
Also, if PIN 46 shows continuity to PIN 48,then the computer would be trying to go into test mode. So you need make sure the PINs you are testing, are the actuall PIN you think you are testing.
Did you try unplugging the O2 harness like I suggested?
V8_Kind_Of_Guy
73
Denver, Co
Jan 19, 2010
#23
  • Jan 19, 2010
  • #23
All of the sensors were disconnected when we tested. we looked at a schematic to make sure we were testing the right wires.
V8_Kind_Of_Guy
73
Denver, Co
Jan 19, 2010
#24
  • Jan 19, 2010
  • #24
No we didn't disconnect the 02 harness, I forgot to do that. One of the first things we did when we started looking into this problem was disconnect the maf sensor. The car seemed to idle ok, so it shows the computer can go into limp mode.
liljoe07
5 Year Member
Feb 18, 2009
1,622
363
124
Cartersville,Ga
Jan 20, 2010
#25
  • Jan 20, 2010
  • #25
Do you still have the jumper wire from the signal return to the STI hooked up at the codes test port? Continuity from PIN 46 to 48 needs to chased down. And if you have continuity from 46 to 26 then some where there is a short on either the Map/bp sensor,EVP, or TPS wiring.
V8_Kind_Of_Guy
73
Denver, Co
Jan 20, 2010
#26
  • Jan 20, 2010
  • #26
Ill be starting some more checks right now and should write back more later today. No I do not have the jumper wire hooked up anymore.
First Prev 2 of 2
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
Running very very rich
  • 2esoteric
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
Engine 1990 LX 5.0L EFI Mustang Fuel Management Problems - HELP!
  • 5.0LXStanger
  • May 25, 2025
  • 2 3
2K
Fox 5.0 Mustang Tech Jul 11, 2025
5.0LXStanger
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
  • dan50
  • Jul 18, 2026
dan50
