F-cam questions
  • Thread starter Thread starter casper98gt
  • Start date Start date Sep 28, 2007
C
casper98gt
66
NH
Sep 28, 2007
  • Sep 28, 2007
I have trickflow upper and lower. Stock heads and valve train. plugs, wires, cap, rotor, and my waterpump **** it. So i am replacing it. I have a f-cam i was going to wait until i put on my vortech before i installed it. But can i install it right now with everything else being stock. Or do i need springs and rockers before i can put it in. I just figured since everything is apart. I might as well just do it now.
Thanks
Fast63
717
  • Sep 28, 2007
You will need new springs in order for it to be worth it. I believe the stock springs are about binding at .500 lift and do not have enough pressure to keep the valves from floating. Even if it did work, your springs would wear out a lot faster. I would just wait until you can change the springs as well.
bentley429
Banned
Nov 25, 2004
528
Connecticut
Sep 28, 2007
  • Sep 28, 2007
Yes you would need new springs, but you wont benifit from a cam until the heads are worked or you put aftermarkets on.
C
casper98gt
66
NH
Sep 28, 2007
  • Sep 28, 2007
Awesome. thanks guys. I know a buddy running a F-cam with stock heads and valvetrain and a supercharger. Should he be worried?
I only went with a F-cam because one of the guys on here sold me. trickflow upper/lower, 42lb'er, sn95 rails, f-cam, vortech and Ford racing x302 heads with valves and springs and 1.7's.
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Sep 28, 2007
  • Sep 28, 2007
Using an increased lift/duration cam will work against your valves more so.
These are the springs that summit racing has for their valve springs for the F-cam:
http://store.summitracing.com/partdetail.asp?part=CRN-99838-16
http://store.summitracing.com/partdetail.asp?part=FMS-M-6513-A50
http://store.summitracing.com/partdetail.asp?part=TFS-2500100
Here is more detailed specs on the F cam in case you were curious:
Cam - Duration @ .050" - Adv. Duration - Valve Lift - Lobe Lift - LSA - Int./Exh. Centerline - Powerband
F303 - 226*/226* - 288*/288* - .512"/.512" - .320"/.320" - 114* - 109*/119* - 2,800-6,000 RPM
1.6 Rocker Ratio
Intake Opening: 4* BTDC
Intake Closing: 42* ABDC
Exhaust Opening: 52* BBDC
Exhaust Closing: 6* BTDC
bentley429
Banned
Nov 25, 2004
528
Connecticut
Sep 28, 2007
  • Sep 28, 2007
Didnt know you were planning on swapping out the heads, sounds like you'll be fine to me now. Just check on the lift for those springs that come on the heads, then use the info 5spd GT gave you. If all checks out well....put it together and make some good power! Dont let ANYone tell you that F303's are junk either.
K
Engine Gt40p vs 180 procomp
  • Kleinjj27
  • Oct 27, 2026
Fox 5.0 Mustang Tech Nov 3, 2026
Kleinjj27
K
A
A/F ratio gauge install questions.
  • AngryH58
  • Sep 24, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 22, 2026
K
Resolved Weird sound coming from a freshly rebuilt 5.0L
  • karhoot
  • Jun 24, 2026
Fox 5.0 Mustang Tech Jun 27, 2026
Mac131
N
Looking for ECU/CHIP for 1992 5.0
  • Nathan26
  • Sep 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 8, 2026
Qtrhrse23
M
Electrical 93 5.0 No Injector Pulse
  • machinermac
  • Jul 26, 2026
Fox 5.0 Mustang Tech Aug 1, 2026
Willybill32
