F/S 1993 Supercharged 306 LX
stang5093
33
East Haven CT
Here are the specs
Sportsman block
JE pistons
Scat crank
42lb injectors
AFM blower cam
1.7 roller rockers
Holley Heads and holley upper and lower intake
BBK ceramic coated shorty headers
BBK High flow catted H pipe into Flowmaster cat back
70mm throttle body
MSD ignition
Cooling mist Meth injection (goes up with the boost)
Vortech S trim blower with 8 rib pulley 13lbs of boost
custom blower air inlet tube
Sniper tune on 10 hours of dyno time
GER ARD transmission with 3000rpm TCT stall converter
Maxium motorsports upper and lower control arms
Weld Racing rims with skinneyd up front and 275 M/T drags out back 15in
B&M hammer shifter
Custom racing seats
Sparco steering wheel
Battery moved to the rear
Eibach springs all around
Autometer tach,boost,temp,air/fuel ratio guages
3.73's
I maybe forgetting a few things, I have had this car sice 01 and have put thousands into this car. It does pass emissions in CT
Best pass at LVD 11.12 at 126.1 with wheel spin up to the 60 foot mark.
Horsepower was 553 RWHP with pump gas and 488tq
horsepower is now set at around 450 for street use
This thing is a beast and will snap your neck. Its not comfortable its not nice riding it dont turn worth a damn,grin on your face when you hit the gas
The bad, the paint it needs a paint job. I have had this car since I was 17 and the cheep high school macco job is wearing off. no test rides because I do not have insurence on it at this time
Car is located in connecticut
Email me at [email protected]
Asking 10k
