failed emissions....HELP
  • Thread starter Thread starter 89notchfox
  • Start date Start date Dec 6, 2005
89notchfox
30
douglasville ga
Dec 6, 2005
  • Dec 6, 2005
Ok heres the deal I have a 89 coupe. It runs good, except it surges at idle sometimes (so bad it stalls). I don't know what that is caused by either. It sounds like a vaccum leak, but I can't find it if there is one. But anyway today when I got the emissions done it failed for CO and HC! Im not sure where to go from here. I just did a tune up about 1,000 miles ago. No check engine light, I don't know whats wrong. The guy who did it said maybe because it was cold out this morning and the car wasn't driven long, but I don't know. If you can point me in the right direction to fix this I would greatly appreciate it. Thanks
quiksilver9531
469
New Jersey
Dec 6, 2005
  • Dec 6, 2005
you wanna make sure you car is at a normal operating temp before testing emissions. The surging at idle could be your IAC, or it could be a vaccum leak, get a can of starting fluid and spray around
djk8705
154
Fairfax, Va
Dec 6, 2005
  • Dec 6, 2005
I'd do my spraying with some soapy water in a spray bottle....
I have heard a few stories about engine bays going up in flames when a small puddle ignites of sprayed brakeclean/ starter fluid ect....
edit- also have seen some pretty poor cars pass emmisions after a BG induction service "kit" was done.. just a thought, I would fix that idle first though. good luck
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Dec 7, 2005
  • Dec 7, 2005
See the sticky "Help me create the Surging Idle Checklist" at the top of the forum for help with your idle problems.
How to pass emissions testing:
1.) Make sure all the emissions gear the car was made with is present and connected up properly. That includes a working smog pump and cats.
2.) Make sure that you have fresh tune up with spark plugs, plug wires, cap, rotor, fuel & air filters. An oil & filter change is a good idea while you are at it.
3.) Dump the codes and see what the computer says is wrong…
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
See http://www.troublecodes.net/Ford/
OR
See http://www.mustangworks.com/article...c-iv_codes.html
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Walmart.
Or for a nicer scanner see http://www.midwayautosupply.com/det...iption.asp?3829 – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $33.
4.) Post the codes and get help to fix them. Don’t try to pass with codes not fixed. Clearing the computer just temporarily removes them from memory, it doesn’t fix the problem that caused the code to be set.
5.) Be sure to do the testing on a hot engine. Drive for 15-20 minutes prior to taking the test to get operating temps up into the normal range. Do not shut off the engine while waiting for your turn on the test machine. An engine up to full operating temperature puts out fewer emissions.
352Ford2
393
Seattle,WA
Dec 7, 2005
  • Dec 7, 2005
Brakeclean is not flamible.
rd
3,316
63
109
Ocean Springs MS
Dec 7, 2005
  • Dec 7, 2005
Jrichker-that $30 code reader is the best item I have seen in a long while! Thanks.
I have the $49 OBD2 Creader, but OBD1's have been frustrating. I even fried my Actron 9145 a month ago on my 89. That"s the episode you solved with the circuit 46 info.
quiksilver9531
469
New Jersey
Dec 7, 2005
  • Dec 7, 2005
lol brake cleaner is very flammable.
djk8705
154
Fairfax, Va
Dec 7, 2005
  • Dec 7, 2005
lol all the ones i use are, i know some aren't tho
J
Emission problems
  • jls.zmmr
  • Feb 5, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Feb 7, 2026
AeroCoupe
G
Need tuning help with 4100 Carburetor
  • Gary’s 67
  • Aug 18, 2026
1965 - 1973 Classic Mustangs -General/Talk- Aug 22, 2026
manicmechanic007
Engine Surging idle on start-up
  • keel
  • Aug 11, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
keel
D
Loud noise(s) from Engine Bay
  • DuluthFoxbody
  • Oct 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 5, 2026
AeroCoupe
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
