  • 1994 - 1995 Specific Tech
Failed Emissions
  • Thread starter Thread starter Guero
  • Start date Start date Sep 9, 2008
Guero
2,148
Sep 9, 2008
  • Sep 9, 2008
Passed- Gas Cap test, Evap Components, and Oxides of Nitrogen(NOX) in grams/mile by 2.16(2.50 is the standard)
I failed- Hydrocarbons in grams/mile by 2.77(1.00 is the standard)
Carbon Monoxide in grams/mile by 21.93(12 is the standard)
What should I do 2 fix it 2 pass?
94-302-vert
1,947
NE CT
Sep 10, 2008
  • Sep 10, 2008
You barely failed man... good job...
I had failed miserably... To pass I ran some "guaranteed to pass" and pulled a TON of timing (I actually pulled the SPOUT) and it passed...
Summar y of my trials:
first time (re installed my high flow cats, hole in air pump supply to cats, no egr): HC 27 of 60, CO .02% (not sure limit), Nox 1370 of 700 : FAIL
2nd time (EGR still non-functional), ran CRC guaranteed to pass, and put some isopropyl alc in the tank): HC: 189, CO 6.4%, Nox 132: FAIL
3rd time (disconnected spout): HC 29, CO: .01%, Nox: 135 : PASS
desertcox05
379
south atlanta
Sep 10, 2008
  • Sep 10, 2008
yup pulling the spout is the trick . it will run up about 3-4000 rpm's but after that forget it. after the test put the spout back in and your all good. just don't drop the spout connector into the fender well (trust me I know)
94-302-vert
1,947
NE CT
Sep 10, 2008
  • Sep 10, 2008
When we tried pulling the spout we tried it while it was still on the rollers and when it looked like it would pass we went back to the counter to "re-schedule" then next open spot.
When asked why it failed we said I forgot to connect comething when I tuned it up.
Zero Signal
2,633
Tucson, AZ
Sep 10, 2008
  • Sep 10, 2008
That's crazy. I passed the test in Tucson which is as strict as Guero's when I had no operating smog pump, gutted cats and a disconnected EGR. I just made it all LOOK like it was working for the flashlight/mirror inspection. The numbers were still pretty clean. I did pull timing with the tweecer and got it running insanely hot without the fan while trying to get it to run lean as well.
desertcox05
379
south atlanta
Sep 11, 2008
  • Sep 11, 2008
not everybody has a tweecer to adj stuff. all most of us have is a timing light and basic hand tools , or maybe the sniffer where you took it to was a bit off. IDK i couldn't get mine to pass till i pulled the spout and i have all the emissions crap installed. maybe someone was in my puter and adjusting stuff before i bought it. IDK
Zero Signal
2,633
Tucson, AZ
Sep 11, 2008
  • Sep 11, 2008
You could still effectively do what I did (by your method of pulling the spout) combined with disconnecting the fan's power to get the car as hot as possible.
k00ksta
158
Chicago
Sep 11, 2008
  • Sep 11, 2008
What car is this still on the 1995 Mustang GT or the 1991 Mustang GT? And where do you live that 1995 and under are not emissions exempt now? Mine Finally just got emissions exempt in IL
desertcox05
379
south atlanta
Sep 12, 2008
  • Sep 12, 2008
ga goes back 23 years
94-302-vert
1,947
NE CT
Sep 15, 2008
#10
  • Sep 15, 2008
  • #10
My mustayng is due for emissions by 10/10.
GTA_V6_Mustang
1,326
Miami, FL
Sep 17, 2008
#11
  • Sep 17, 2008
  • #11
your running rich there buddy. Maybe if you have an Adjustable FPR turn it down a bit. those numbers indicate rich.
BYRDPE
1,556
Memphis,Tn.
Jun 11, 2009
#12
  • Jun 11, 2009
  • #12
When you pull the spout what should the timing be set at prior to getting the car smogged?
Is this in reference to a test on the rollers?
I only have the sniffer test and I failed the HC. I'm going to reinstall my stock hpipe so it should come down to 440 from 903...the standard is 220.
Hopefully by lowering the fp from ~42 to 39 and pulling the spout will get me there. Just need to know where to set timing.
BTW....the car is chipped so can I still pull the spout and get results?
Any other sugesstions are welcome.
Thanks
desertcox05
379
south atlanta
Jun 12, 2009
#13
  • Jun 12, 2009
  • #13
I have my timing set to 12 all the time ( stock timing is 10*). All I do is pull the spout then get it sniffed. they don't take it over 2000 rpm on the rollers. IDK about having a chip and pulling the spout but I don't think it would matter. Also get the cats good and hot before the test and i don't mean city driving either (RUN that mother)
J
Engine No power after idle
  • JustinTilley86
  • Aug 10, 2024
3K
Fox 5.0 Mustang Tech Sep 23, 2024
General karthief
R
Rebuilt 5.0 - blow by, how much is too much….
  • RockOn
  • Apr 10, 2023
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 12, 2023
RockOn
R
R
2004 Ford Mustang V6 3.9L OBD2 Codes P1000 and P0455 (x2)
  • ROBERTOS2004Mustang
  • Oct 12, 2020
7K
1996 - 2004 SN95 Mustang -General/Talk- Dec 1, 2020
Decipha
Exhaust Header issues - Follow up of my emission issue thread
  • grayvixen93
  • Nov 17, 2020
4K
Fox 5.0 Mustang Tech Dec 31, 2020
90sickfox
95 mustang emissions issues
  • Cannon77550
  • May 21, 2018
2K
1994 - 1995 Specific Tech May 24, 2018
jozsefsz
