  • SN95 4.6L Mustang Tech
Failed Smog....Need some help
  • Thread starter Thread starter Cheps
  • Start date Start date Mar 19, 2004
C
Cheps
82
So. CAL
Mar 19, 2004
  • Mar 19, 2004
Failed the Smog test today. I had too high hydrocarbons. The guy said the car is probably mis-firing. What should I do?
I also failed the MIL/check engine light part. What should I do about that?
I little history of my car. I bought used and it came with an off-road h-pipe. I welded some cats on the onto the pipe. I'm not sure if the guy who owned it before had gotten MIL elimators on it. But the check engine light isnt on.
Last time i smog it it wasnt a problem.
Thanks for the help
Does anybody know a smog friendly place in Southern California
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Mar 19, 2004
  • Mar 19, 2004
check and see if there are any codes that dont flash the CEL. what kind of cats are on the pipe? i dunno about farther south, but around here they (CARB) have been sending around a lot of undercover cars and issuing fines to the shops here.
03poontanggt
296
fresno ca
Mar 19, 2004
  • Mar 19, 2004
If the smog guy knows anything about mustangs he wont pass because they aren't the original cats, in ca they wont pass any thing that has aftermarket high flow cats or anything like that.
2002BLGT
Well-Known Member
Dec 18, 2003
2,945
Bedford VA
Mar 19, 2004
  • Mar 19, 2004
california emissions SUCK , im glad im in VA we only have a visual inspection here so half the cats you see on anything around here , they dont have crap on the inside LOL .
DBMSTNG
I fantasize about it being BIG!
2,120
not quite here
Mar 19, 2004
  • Mar 19, 2004
Thanks for the help
the previous owner had MIL eliminators on the car. if you did not remove the eliminators and put the sensors back in, that is your problem.
FR-S8N
1,306
McAllen, tx
Mar 19, 2004
  • Mar 19, 2004
go somewhere.. where you can give them a couple extra bucks to let you pass.
R
rob1
94
Indiana
Mar 20, 2004
  • Mar 20, 2004
Do they smog test in every state? I live in Indiana and haven't ever seen smog testing. Could this be a future problem?
SteveoGT
40
East Bridgewater
Mar 20, 2004
  • Mar 20, 2004
Usually high hydrocarbons come from a whole lotta different things, i dont stickers in MA. it could be a bad maf, map, 02sensor, a dirty air filter, if u havent changed your oil in a while, just a whole junk load of things. theres 2 tests that we do, a 2speed idle, which he did to ur car, and then the dyno test, which he should have done. Im almost positive if u go to another station and do the dyno test that you'll pass with flying colors. just make sure that the guy does thae dyno test or else u'll probably fail again. but just for safety sake, id check all ur connections, ur plugs, air filter. run some high test in the car with some fuel injector cleaner for about a week u should be fine..
mrvax
Stay thirsty my friends
SN Moderator: Orlando, Fl.
Mar 20, 2004
  • Mar 20, 2004
And make sure the car 100% up to temperature when the test starts. Spark plugs can also be a culprit.
C
Cheps
82
So. CAL
Mar 20, 2004
#10
  • Mar 20, 2004
  • #10
Thanks guys....I havent changed the oil in 4000 miles (1000 overdue). I'll also do the tuneup and fuel injection cleaner...wish me luck.
Abso
48
#11
  • Mar 20, 2004
  • #11
Cheps where in So Cal are you? There is a place in Hollywood that will pass you. Might cost you an extra 20 bucks, but they passed my friends car which is hardly legal.
C
Cheps
82
So. CAL
Mar 20, 2004
#12
  • Mar 20, 2004
  • #12
I'm in Hawthorne....where the 405 and the 105 meet. Shoot me a PM or e-mail me at Chepsx@hotmail.com
White Stang
467
Ft Lauderdale
Mar 20, 2004
#13
  • Mar 20, 2004
  • #13
We use to have inspections in Florida but not anymore I guess are smog problem went away.
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
T
Looking for some help with 2006
  • thedudeillest
  • Mar 16, 2026
2005 - 2014 S-197 Mustang -General/Talk- Mar 20, 2026
Cooling Jacket Pitting Idea's?
  • BoostedRed89gt
  • Aug 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 17, 2026
Mustang5L5
  • Gulftown980x
  • Jul 29, 2026
squeak93
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
